D16A6 CRX Si Troubleshooting questions
Old Oct 23, 2003 | 03:16 PM
archie1709's Avatar
Default D16A6 CRX Si Troubleshooting questions
I have a 1990 Honda CRX HF with a D16A6 engine. New radiator(Si), new water pump and belt job, reman-ed Si knuckles, reman-ed Si axles, new 2" pipe, new cat, headers, aem cool air, new dynomax turbo muffler, new intake manifold and new throttle boddy (both factory), and new brake master cylinder.
The engine sat for more than 3years in my garage. It has low mileage (I think 35K~long story)
Question: There's white/gray-ish smoke coming out of the muffler. Idling seems ok. All emission components intact. Temp Perfect. I looked at oil cap for any "white stuff" but it looks clear. So I have no reason to believe that head gasket needs replacement. Engine R&R was done two weeks ago(Oct 10).
Could it just be water condensation? If it is, how long does it normally stay that way. I am worried because I want to pass smog.
Please Help!!
Old Oct 23, 2003 | 03:38 PM
EL Vap133's Avatar
Default Re: D16A6 CRX Si Troubleshooting questions (archie1709)
Did you add new gas and let the old one burn out?
Old Oct 23, 2003 | 03:53 PM
archie1709's Avatar
Default Re: D16A6 CRX Si Troubleshooting questions (EVIL_Vap133)
I had a full tank of gas before R&R, then I had half of that by the time it was done (I guess the guy drove it around for tests). Then I finished two tanks already by now and I can still see smoke everytime I dog the rex. I mean, I just punch the throttle once in a while and I always see this smoke coming out. even my cousin noticed it.
Old Oct 23, 2003 | 04:00 PM
Outsane's Avatar
how is your oil and coolant level? had it changed at all?
Old Oct 23, 2003 | 04:04 PM
archie1709's Avatar
Default Re: D16A6 CRX Si Troubleshooting questions (Outsane)
Good question...my coolant seems fine but i am probably buring oil because of this:
The last time I checked a week and a half ago (after I had my mufflers done) my oil level is at 50% on the dipstick. Then I checked again last Monday, and it was around 30% on the dipstick. The weird thing is, when i added one quart of synthetic oil, it's back up to 100%. Very weird.
Long story short. Coolant OK, oil a bit unsure.
Old Oct 23, 2003 | 04:19 PM
Outsane's Avatar
did you check the oil after the car had sat for a bit?
Either way sounds like your burning oil..
could be rings, pcv valve, valvestem seals...to name the easy ones..
Old Oct 23, 2003 | 04:25 PM
archie1709's Avatar
Default Re: (Outsane)
I believe the shop did. They flushed it and put new oil. The guys at the shop told me to flush the engine after 500 miles and put a 5W30 oil and "Restore".
You think I am burning gas? I hope it has nothing to do with piston rings because I am all broke. It is a low mileage engine after all.
Old Oct 23, 2003 | 04:28 PM
Outsane's Avatar
Default Re: (archie1709)
I hope your burning gas...If your burning too much fuel, the smoke would be black, oil has a bluish color, and coolant should smell sweet..
Restore is a temporary fix...if it works..
TYPEcRx
Nov 16, 2010 05:45 PM
mykoe817
Jul 19, 2007 05:30 PM
cal_gecko
Oct 17, 2006 07:14 AM
Count Blah
Dec 15, 2002 11:16 AM
mazdaspeed00
Aug 29, 2002 07:03 PM
