What oil to use after rebuild?
Old Oct 23, 2003 | 03:16 PM
CroSi's Avatar
Default What oil to use after rebuild?
What oil should I use right after I rebuild my D16A6?
Old Oct 23, 2003 | 03:32 PM
SIRX's Avatar
Default Re: What oil to use after rebuild? (CroSi)
10w30 will be fine. if your going to be hammering on it I'd go with 10w40
Old Oct 23, 2003 | 03:34 PM
Ef Whore's Avatar
Default Re: What oil to use after rebuild? (SIRX)
I'd just use the normal 5w-30 that Honda has from the factory. Quaker State is what I use, and also what Honda recommends.
Old Oct 23, 2003 | 04:01 PM
Outsane's Avatar
Default Re: What oil to use after rebuild? (Ef *****)
just don't use synthetic for while..
Old Oct 23, 2003 | 06:23 PM
model x's Avatar
Default Re: What oil to use after rebuild? (Outsane)
I'd use Valvoline Maxlife, it has very good anti-friction additives and more zinc than most other oils. A few guys on here that knew way too much about oil recommended it.
Old Oct 23, 2003 | 06:28 PM
sporkcrx's Avatar
Default Re: What oil to use after rebuild? (model x)
I just used the normal 5-30. Cranked it over till I got pressure, turn it on, checked for leaks, then went out and mashed it Holdin up fine...probably about 1000 miles so far. Perfect compression still
Old Oct 23, 2003 | 06:36 PM
USDM 4G VTEC's Avatar
Default Re: What oil to use after rebuild? (sporkcrx)
right after rebuild.... and first crank..... get a light oil..... cheap one..... 5-30 its good
after a week or 500 miles change the oil for 10-30 and not synthetic.,,,
our old engines seem not to like synthetic .... at least on my case......
Old Oct 23, 2003 | 10:30 PM
Outsane's Avatar
Default Re: What oil to use after rebuild? (USDM 4G VTEC)
if its an old enigne.. it might not like synth.. on a rebuilt with a couple k on her...they love synth
Old Oct 23, 2003 | 10:51 PM
SOHCEK-Turbo's Avatar
Go with penzoil or quaker State they are the same company they have the best additives for conventinal. Stay away from conventional Valvoline that includes maxlife. Those have the worst additives. And Ya Synthetic is cool for rebuilt engines like Mobil1 Valvoline Synpower and Castrol Synthetic. I would go with Mobil1 since its the only true Syntetic.
Old Oct 24, 2003 | 04:23 AM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">right after rebuild.... and first crank..... get a light oil..... cheap one..... 5-30 its good
our old engines seem not to like synthetic .... at least on my case......</TD></TR></TABLE>
I agree, a cheap 5w-30 oil is what you should run right after a rebuild.
Right after a rebuild, I run the motor for 20 minutes and them promptly change the oil. Maybe its a bit over board, but I'd rather get all the possible loose crap out of the motor ASAP.
Old Oct 24, 2003 | 05:40 AM
1st-hybrid's Avatar
This may be a bit OT, but I've been waiting to spread this around
If you have any questions about oil check this out: http://www.vtr.org/maintain/oil-overview.html.
There is more info than most people will need on oils to make informed decisions.
Modified by 1st-hybrid at 11:31 AM 10/24/2003
Modified by 1st-hybrid at 11:34 AM 10/24/2003
Old Oct 24, 2003 | 07:17 AM
MrTodd's Avatar
Default Re: What oil to use after rebuild? (1st-hybrid)
I wouldn't say that site has more info than you'll ever need about motor oil... It says/compares nothing about synthetic motor oils.
But still nonetheless, a good informative website!
Old Oct 24, 2003 | 07:19 AM
senpai's Avatar
Default Re: What oil to use after rebuild? (MrTodd)
I used NAPA non-detergent 30W oil @ $1.29/qt
Old Oct 24, 2003 | 07:39 AM
1st-hybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't say that site has more info than you'll ever need about motor oil... It says/compares nothing about synthetic motor oils.
But still nonetheless, a good informative website! </TD></TR></TABLE>
Valvoline Synthetic 146 465 -40 &lt;1.5 .12
And a few others
Old Oct 24, 2003 | 07:45 AM
MrTodd's Avatar
You're right - sorry, apparently I'm in '***' mode today, so I need to calm down.
Old Oct 24, 2003 | 07:47 AM
1st-hybrid's Avatar
No harm no foul man we all have our days. I have my weeks
Old Oct 24, 2003 | 04:27 PM
Donkey85's Avatar
Castrol GTX 5w30 or 10w30 depending on your climate
Old Oct 24, 2003 | 08:53 PM
Steve91's Avatar
10w 30 is fine. You can run synthetic from day one if you want. Every Porsche, Ferrari, Corvette, M3, etc made today leaves the assembly line with synthetic in the pan.
Old Oct 24, 2003 | 11:05 PM
Ef Whore's Avatar
Default Re: What oil to use after rebuild? (Steve91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve91 &raquo;</TD></TR><TR><TD CLASS="quote">10w 30 is fine. You can run synthetic from day one if you want. Every Porsche, Ferrari, Corvette, M3, etc made today leaves the assembly line with synthetic in the pan.</TD></TR></TABLE>
Just use the 5w30 Quaker State non-synth. that is meant to be in there.
Old Oct 25, 2003 | 06:08 PM
HondaMPower's Avatar
Default Re: What oil to use after rebuild? (civicdriver91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdriver91 &raquo;</TD></TR><TR><TD CLASS="quote">Mobil1 since its the only true Syntetic. </TD></TR></TABLE>
Old Oct 25, 2003 | 06:45 PM
CroSi's Avatar
Default Re: What oil to use after rebuild? (HondaMPower)
What about 5W-30 Castrol GTX? Im assuming thinner is better because it gets inbetween all the moving parts easier.
Old Oct 25, 2003 | 08:04 PM
PhatOptimo's Avatar
Check into AMSoil. Best stuff out there.
BoBo Racing
Honda S2000
Aug 24, 2003 07:03 PM
E Swift
Aug 23, 2003 01:01 AM
Evil_Wizard
52
Oct 28, 2002 09:05 AM
turrismaldon
Aug 31, 2002 09:37 AM
CTR94Joes
Jan 27, 2002 11:03 AM
