F/S: T3/T04B, V-AFC, Misc D16Y8/B18B Stuff
Old Oct 23, 2003 | 01:08 PM
inspyral's Avatar
Default F/S: T3/T04B, V-AFC, Misc D16Y8/B18B Stuff
Check here if pics aren't showing up:
http://www.imagestation.com/album/?id=4286127583
Turbonetics T3/T04B - ~1000mi on cheapturbo.com rebuild, turbine is a 5-bolt .63 a/r T3 with a stage 3 wheel, compressor is an S trim(I think) T04B, wet center housing(water cooled), pristine condition, comes with water fittings, $380
Blue H-Brace for 92-00 Civics - Pretty much brand new, installed once then removed because of clearance issues with my cat, brace fits very snug(had to muscle it in place to get all the bolts in), ground clearance is bit on the low side, looking to get back what I paid for it, $50shipped
A'PEXi V-AFC - used for ~2 years, still in great shape, display has some minor glitches(a couple pixels here and there don't light up) that don't affect functionality at all, comes with instructions, stand, harness/sub-harness all in the original box, $200 obo
D16Y8 starter motor - off a 97 EX MT, $50
D16Y8 head - valvejob, resurface, hot-tank performed ~1000 miles ago; cam has a chunk missing from the distributor end(it still works fine, but you'd probably want a new one); has extended studs on intake side for Hondata gasket; small grooves in cam journals from when I lost oil pressure(probably needs an allign-hone); does not come with VTEC solenoid/pressure switch, valvecover, or distributor, make an offer
D16Y8 Shift Linkage - comes with poly ES bushings, $30
D16Y8 oil pump - ~1000 miles on it, $30
D16Y8 internals - complete internals from my 97 shortblock, #3 piston has cracked ringlands, make me an offer
D16Y8 backup light switch - $15
D16Y8/B18B engine mounts - D16Y8 AC mount, front tranny mount, upper tranny mount(on chassis), rear chassis mount, rear tranny bracket; LS front torque mounts(on chassis); make an offer an any or all
OEM rear dampers(shocks) - fit 96-00 Civics(all), $25
OEM Rear LCA's - fit 96-00 Civics, $40
OEM springs - fit 92-00 Civics and 94-up Integras, $40
OEM Civic shifter arm - $15
OEM Civic radiator fan - $20
OEM LS shifter arm - $15
98 LS power steering pump, pulley, belt, bracket - 60k miles, $50
98 LS clutch, pressure plate - 60k miles, good amount of meat left, $40
98 LS flywheel - 60k miles, good condition, $40
98 LS fuel pump - 60k miles, make an offer
98 LS intake manifold bracket - make an offer
OBD-II injector clips - make an offer
OBD-I injector clips - $15
Hydro clutch slave cylinder - comes with Integra softline and short hardline, $30
96-98 Civic front bumper - OEM Vogue Silver Metallic, came off a 98 EX coupe, great overall condition, grille also included(but you would probably want to replace it with some mesh or something since it was cut out to fit around fog lights), grille trim piece was scratched and touched up, $40
________________
Buyer pays shipping costs on all items, unless otherwise noted.
All parts listed are from a 97 Civic EX or 98 Integra LS, unless otherwise noted.
I'm in San Jose, Cali.
Modified by inspyral at 3:51 PM 8/14/2004
Old Oct 23, 2003 | 02:24 PM
abs0lutexer0's Avatar
sup chris, remember me? i left u a note on your car at the 4th st garage at sjsu... r u boosting your LS yet?
Old Oct 23, 2003 | 04:17 PM
inspyral's Avatar
Default Re: (abs0lutexer0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abs0lutexer0 &raquo;</TD></TR><TR><TD CLASS="quote">sup chris, remember me? i left u a note on your car at the 4th st garage at sjsu... r u boosting your LS yet?</TD></TR></TABLE>
No boost yet. I need money, so I'm selling some stuff.
Old Oct 23, 2003 | 04:36 PM
fatrhino's Avatar
pic of the turbo?
Old Oct 23, 2003 | 07:12 PM
Del_Slowest's Avatar
Default Re: (fatrhino)
you willing to go down on the price for the o2 sensors
Old Oct 24, 2003 | 10:17 AM
inspyral's Avatar
No recent pics as of yet, since I don't have a digicam.
I can do $40 shipped per O2.
Old Oct 24, 2003 | 10:40 AM
hulkhb's Avatar
Default Re: (inspyral)
pics of the turbo when you get them please
Old Oct 24, 2003 | 02:45 PM
BioXide02's Avatar
Can you send me pics of one of the 4-wire O2 sensors splatmycat@hotmail.com
Old Oct 24, 2003 | 02:48 PM
inspyral's Avatar
As stated above, I don't have a digicam, so I don't have any pics of most of this stuff. If I can get a hold of a digicam to use, pics will be posted then. I would normally just throw smaller items on my scanner, but it seems to be dead.
Old Oct 25, 2003 | 03:43 AM
turboITR#704's Avatar
Default Re: F/S: T3/T04B, V-AFC, Misc D16Y8/B18B Stuff (inspyral)
I might be interested in that. Just real nervous about buying on H-T!
Old Oct 25, 2003 | 11:09 AM
inspyral's Avatar
Default Re: F/S: T3/T04B, V-AFC, Misc D16Y8/B18B Stuff (turboITR#704)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboITR#704 &raquo;</TD></TR><TR><TD CLASS="quote">I might be interested in that. Just real nervous about buying on H-T! </TD></TR></TABLE>
I hear that, buying stuff on HT has gotten pretty sketchy these days. I just had to do a chargeback because of a flakey seller who sat on my money for over a month
Old Oct 26, 2003 | 04:37 AM
What do you mean buy a charge back you got your money back for a scammer? Because I would love to get my money back from some little ricer that beat me in the head $500 smackers, For the same kind of turbo that makes me think that H-T sucks But if you are still selling that turbo Im interested.......
Old Oct 26, 2003 | 07:45 AM
inspyral's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboITR#704 &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean buy a charge back you got your money back for a scammer? Because I would love to get my money back from some little ricer that beat me in the head $500 smackers, For the same kind of turbo that makes me think that H-T sucks But if you are still selling that turbo Im interested.......</TD></TR></TABLE>
I paid a deadbeat seller by the name of "JDMisGOOD" and waited for a month and I got were excuses, so I filed a complaint with PayPal and initiated an investigation with my credit card company.
Old Oct 27, 2003 | 06:23 AM
Tony Starks's Avatar
PM'ed you on the AC mount.
Old Oct 27, 2003 | 09:34 AM
inspyral's Avatar
Default Re: (Tony Starks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony Starks &raquo;</TD></TR><TR><TD CLASS="quote">PM'ed you on the AC mount.</TD></TR></TABLE>
email replied
Old Oct 27, 2003 | 05:25 PM
egjoe's Avatar
you can trust him
bump for you sir.
Old Oct 27, 2003 | 05:37 PM
inspyral's Avatar
Default Re: (egjoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egjoe &raquo;</TD></TR><TR><TD CLASS="quote">you can trust him
bump for you sir.</TD></TR></TABLE>
Thanks Joe
Old Oct 29, 2003 | 02:20 PM
Got the O2 sensor today. Looks great and you packed it very very well. thanks again!
Old Oct 29, 2003 | 04:14 PM
inspyral's Avatar
Default Re: (Del_Slowest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest &raquo;</TD></TR><TR><TD CLASS="quote">Got the O2 sensor today. Looks great and you packed it very very well. thanks again!</TD></TR></TABLE>
Thank you, sir. Glad to hear it made it to you without incident.
Old Oct 30, 2003 | 01:18 PM
AB16A2T's Avatar
Chris is a good guy, buy his gear!
Old Oct 30, 2003 | 04:18 PM
inspyral's Avatar
Default Re: (AresFD3S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AresFD3S &raquo;</TD></TR><TR><TD CLASS="quote">Chris is a good guy, buy his gear! </TD></TR></TABLE>
Thanks Chris
Old Oct 31, 2003 | 05:54 PM
lagingtorpe's Avatar
hey can the power steering package work for my 96 hatch dx hatch?
Old Oct 31, 2003 | 05:55 PM
Default Re: (lagingtorpe)
if so are there anymore parts needed?
Thanks
Old Oct 31, 2003 | 07:40 PM
The Destroyer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">
No boost yet. I need money, so I'm selling some stuff.</TD></TR></TABLE>
I know how that feels.
Old Nov 1, 2003 | 11:13 AM
inspyral's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lagingtorpe &raquo;</TD></TR><TR><TD CLASS="quote">hey can the power steering package work for my 96 hatch dx hatch?</TD></TR></TABLE>
It's just the pump and bracket, it's not complete. I wouldnt know if it'll work with your setup.
