Can you tell me if I need new struts???
Old Oct 23, 2003 | 12:59 PM
shadow103rd's Avatar
Default Can you tell me if I need new struts???
Ill try and post pics when I get home tonight from work.
Put on some new lowering springs, Goldline springs, After I finished the install check the spring seats and everything checked out okay. When we got the car on the ground and after about an hour of driving the car settled and the passenger side settled higher than the driver side. Its about 3/4 to 1 1/4 of an inch, not sure, but will measure when I get home.
BTW, I got ran of the road by a huge Superduty, about 6 months ago, Had to put used struts on the passenger side, front and back, Honda struts were on back order for about 6 weeks, so used struts got put on.
Could I possibly need new struts.
Please any advice would be appreciated
Old Oct 23, 2003 | 01:01 PM
jolt-tsp's Avatar
Default Re: Can you tell me if I need new struts??? (shadow103rd)
I don't think the shocks are really gonna help you in that area. How much of a drop was it? it's normal for it to be off balace like that, but thats a big difference, so it seems like it musta been quite a drop
Old Oct 23, 2003 | 01:03 PM
Default Re: Can you tell me if I need new struts??? (jolt-tsp)
Brought it down 2 1/4 all around
Old Oct 23, 2003 | 01:11 PM
bump
Old Oct 23, 2003 | 01:21 PM
SOHC_MShue's Avatar
you should have aftermarket struts with it lowered. Do the right thing and buy some.
Old Oct 23, 2003 | 01:31 PM
Default Re: Can you tell me if I need new struts??? (SOHC_MShue)
Ive had a lowered car without aftermarket struts and it was perfect. settled straight and everything. Rode like a lowered car.
any suggestions on which struts to buy
Old Oct 23, 2003 | 01:43 PM
Tad's Avatar
Tad
usually the passenger side will sit lower than the drivers side(in the front at least).
unless you do something to correct it.
but definetely NOT more than an inch of difference, over an inch probably means you did something wrong with the install, or something else is wrong.
Old Oct 23, 2003 | 02:36 PM
Default Re: (Tad)
bump
Old Oct 23, 2003 | 02:46 PM
Default Re: (shadow103rd)
help a brotha out...bump
Acco12dv6
Jul 20, 2007 10:37 PM
mattmw88
Mar 20, 2006 02:30 PM
ds2000
Sep 4, 2003 12:30 AM
94-TVR-Civic
Oct 17, 2002 05:30 PM
EVIL Hx Coupe
Sep 3, 2002 12:30 PM
