H22 dyno results - 209 whp
Just got back from the dyno and I'm very happy with the results
Setup:
1995 JDM Prelude VTEC H22A Engine & 5spd Transmission w/ LSD
Golden Eagle Godzilla Sleeves
87.25mm Prelude Type-S Pistons
Head Milled 0.020"
Modified Intake Manfiold
Crower Stage 2 Camshafts
Imagine Engineering 4-2-1 Header
Imagine Engineering 3" Race Intake
STR Cam Gears
STR 70mm Throttle Body
AEM High Flow Fuel Rail
AEM Adjustable Fuel Pressure Regulator
APEXi V-AFC
Thermal Classic Exhaust
NGK Spark Plug Wires & Platinum Plugs
No P&P on the head yet!
This is in a 2000 lb 94 Civic hatch. Going to the track Saturday
Motor:
Setup:
Head Milled 0.020"
STR Cam Gears
APEXi V-AFC
Motor:
i plan on going with an h22 in my dc and i was woundering if you can tell me what axles, and shift linkage would i use if i use the place racing mounts?
very impressive #'s
very impressive #'s
We just finished installing H-22 into 94 civic hatch(jap spec all stock),then the costomer went to the track and ran numerous 13.8 passes and a best of 13.78@103 with street tires.Yours should run at least high 12s at 110.
Good luck
Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thedread »</TD></TR><TR><TD CLASS="quote">Why did you resleeve for type S pistons? Are those numbers from a dynojet?
same thing i was wondering... but nice #'s
Thanks guys.
This is on a DynoJet.
I have the GE sleeves with the Type-S pistons because I had to get a new block and Import Builders was able to hook me up with one that was already sleeved for a great price. In the future I'll probably be putting in some higher compression pistons. Right now I'm around 11.5:1.
The car feels great and I can't wait to see how it does at the track. I ran consistant 13.8's at 185 whp and 2200 lbs on street tires earlier this year. Now I have some suspension mods, traction bar, 200 lb lighter car, 20 more hp, and slicks.
Thanks guys. I like these numbers just as much, if not better:
12.82 @ 110 mph
https://honda-tech.com/zerothread?id=659109
12.82 @ 110 mph
Yuleluder
78
Mar 20, 2006 10:20 AM
ranta18
55
Jul 18, 2003 03:18 PM
that must be one fun civic to drive on the street.
