Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Legend Engines???
Old Oct 23, 2003 | 12:19 PM
pimpwok's Avatar
Default Legend Engines???
what's the difference between type one and type two engines, other than the obvious hp difference?
-thanks in advance
Old Oct 23, 2003 | 09:16 PM
RangerJoe's Avatar
the type 2 has different heads and a different exhaust manifold, giving it 30 extra horsepower. the type 2 actually has 2 less ft lbs of torque, but that isnt noticeable.
other than the heads/intake manifold, and the 94-95 type 2 engines had the R-134a coolant instead of the R-12 system, they are virtually the same....the bottom end is the same, but the type 2 has a different flywheel setup.
Old Oct 26, 2003 | 09:41 AM
ZylexSNL's Avatar
RIP ILL: 26Jan1945-02Feb2017 -&- JLVK: 14Jun1925-13Dec2016
Community Builder
Community Influencer
Default Re: (RangerJoe)
dont forget the 6-sp tranny, too...
Modified by ZylexSNL at 8:13 PM 10/28/2003
Old Oct 26, 2003 | 09:34 PM
Matgallis's Avatar
Default Re: (ZylexSNL)
and the uber 1337ness
Old Oct 28, 2003 | 03:15 AM
1bad-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZylexSNL &raquo;</TD></TR><TR><TD CLASS="quote">dont forget the 6-sp tranny, too... </TD></TR></TABLE>Ahh yes, the 6 speeds. They're sweet.
Old Oct 28, 2003 | 11:03 PM
RangerJoe's Avatar
the 6 speed on legends is mostly for bragging rights. as far as gearing, it is roughly the same. 3rd gear is a little shorter i believe.. it is good for gas milage also, not all that much better, but maybe 2-300rpm difference at 80mph.
id rather have a 5 speed. less complicated, less weight, and much cheaper to fix if necessary.
Old Oct 30, 2003 | 12:25 PM
pimpwok's Avatar
exactly what is the difference in the two heads?
Old Oct 30, 2003 | 12:37 PM
RangerJoe's Avatar
i have no clue.
Old Oct 31, 2003 | 02:36 AM
pimpwok's Avatar
where can i go about procuring Type-2 parts?
Old Oct 31, 2003 | 07:17 AM
RangerJoe's Avatar
http://www.car-parts.com
when you search, just look for 93-95 coupe parts
Modified by RangerJoe at 11:56 PM 12/3/2003
Old Dec 3, 2003 | 01:48 PM
96-EJ6 B18C's Avatar
Anyone know where I can get ahold of a GenII C32 engine, tranny and ecu???
Old Dec 3, 2003 | 02:56 PM
RangerJoe's Avatar
http://www.car-parts.com is the best place to find low mileage engines for legends, along with transmissions and ECUs.
951kader
Jan 29, 2012 09:30 PM
03dc5Ray
May 18, 2008 12:37 AM
pouponu
14
Apr 1, 2008 10:47 AM
PePpeRedDc5
Mar 2, 2005 03:54 PM
