Rear drum to disk brakes, MC, booster, or prop. valve needed?
Old Oct 23, 2003 | 08:21 AM
crexer's Avatar
Default Rear drum to disk brakes, MC, booster, or prop. valve needed?
I know its been discussed several times but just to make sure if I swap out my 88 dx drums on my crx with crx si disks, do I need an integra booster or proportioning valve? Ive heard to many opinions...just the proportioning valve....or everything......which is it?
Old Oct 23, 2003 | 08:30 AM
buzboy's Avatar
I did this on my 99 civic hatch. I didnt change the booster nor the pro' valve. No problems here.
Phatwhippin_CRX's Avatar
Default Re: Rear drum to disk brakes, MC, booster, or prop. valve needed? (crexer)
i would definitely go with both, you'd rather be sure that you're not gonna have 'soft' brakes, right?
Old Oct 23, 2003 | 09:13 AM
crx98's Avatar
Default Re: Rear drum to disk brakes, MC, booster, or prop. valve needed? (Phatwhippin_CRX)
some people say its better to have the MC, booster, and prop valve from a DA integra.
some people say its fine without any of it.
i say.. see how the braking is without any of it.. if its good enough for you, then your set.... but if its not good enough for you, then get the MC, booster, prop valve from a DA integra.
Old Aug 17, 2004 | 05:26 AM
I Have an STD's Avatar
wrenchin'
Default Re: Rear drum to disk brakes, MC, booster, or prop. valve needed? (crx98)
no, it is not needed.
Brett
jakfrost84
10
Mar 20, 2009 11:22 AM
89efDUSTY
13
Mar 26, 2007 11:20 PM
go2sleep
May 27, 2005 09:29 AM
crexer
10
Apr 17, 2004 09:13 PM
civic dx
Jun 25, 2003 12:38 AM
