help me diagnose which axle has gone bad?????
well i went to the track with thoses napa axles, but long story short its making clicking sounds. I know that if its clicking when i make sharp turns then the axles will become bad soon. The only thing is i dont know which axle is broke. So far i have only noticed the clicking sounds when i make a hard RIGHT turn. Please help me diagnose which side. Thanks in advance
Look to see if theres any grease leaking from the rubber boot on both inner and outer joints on both axles. usually the bad one will be leaking or the boot completely torn
so i made a few hard left and right turns today, nd it turns out that it only clicks when i make right turns
Your outboard CV joint may be damaged or worn out man...
You hear a clicking sound making a right? Then it must be the driver's side axles..
JDM R
12
Aug 27, 2004 04:15 PM
StreetwizeRacin2
10
Nov 5, 2003 07:33 PM
