B-block Intake on a D-block motor... What to expect? Help!
Old Sep 4, 2001 | 04:05 AM
il8apex's Avatar
New User
Default B-block Intake on a D-block motor... What to expect? Help!
I can't modify my engine internally (SCCA IT racing) so I'd like to work the intake a bit. Two Part Question:
Will a B-block intake (B18A, for instance) fit onto the D-block? Is the spacing the same? I realize that there will probably be some matching to do and the mount holes won't line up, but would like to know if it's possible.
Should I expect to see any improvements (breathing and fuel delivery) by putting the B intake on the D-block?
Any help is appreciated...
-T
Old Sep 4, 2001 | 04:59 AM
sohc_boy's Avatar
Default Re: B-block Intake on a D-block motor... What to expect? Help! (il8apex)
won't fit. the best intake manifold i think for the d-series would be one from a 96-00 ex that will work for u, unless of course u already have a 96 up ex.
Old Sep 4, 2001 | 06:52 AM
B18C-EJ1
Guest
Posts: n/a
-T
Completely different.
Old Sep 4, 2001 | 10:09 AM
optiontoo's Avatar
New User
If rules allow, port the D-series intake manifold. The key will be increasing plenum volume as much as you can... grind it until the metal is 0.001" thin if you can! Just make sure the intake manifold port isn't larger than the head port. The throttle body opening should be very close to the same size as the t/b port on the intake but not any smaller.
Old Sep 4, 2001 | 10:56 AM
jjohnston's Avatar
New User
Default Re: B-block Intake on a D-block motor... What to expect? Help! (optiontoo)
Non of these mods are allowed per SCCA IT rules. I assume the car is a 88-91 SI? If so you have to use an 88-91 SI intake. It can only be port matched within one inch of the flange. No porting of the throtle body or TB side of the manifold.
Old Sep 4, 2001 | 05:47 PM
il8apex's Avatar
New User
Default Re: B-block Intake on a D-block motor... What to expect? Help! (jjohnston)
The car's a '93 EX Coupe. The '94 and '95's were just recently classified by Denver (now Topeka) in ITS. The '93 will follow...
Yep, yer right about the 1" rule.
-T
blacc_ej1
Mar 28, 2010 09:27 PM
TMC_EF
Oct 3, 2007 07:51 PM
Teamdiesel
Sep 6, 2007 08:08 PM
Ek9kidd
May 1, 2007 04:06 PM
RA217252
May 25, 2005 05:59 PM
