mpfi swap complete...code 4
Old Oct 22, 2003 | 08:57 PM
xvracing's Avatar
Default mpfi swap complete...code 4
I completed my mpfi swap and it runs and sounds really good. I just can't figure out why I am getting a code 4 (crank angle sensor). I checked the five times and I know I got it right. And yes I did sauder and heat shrink all conections. I have it wired like this: c1-blue/green, c2-blue/yellow. Does anyone have any idea how to fix this. My car only revlimits to 3k rpm with the check engine light on, so I havent really got to feel the power difference yet and its driving me crazy! Please help!
Thanks
Old Oct 22, 2003 | 09:14 PM
EG8R's Avatar
Default Re: mpfi swap complete...code 4 (xvracing)
Have you reset the ECU? And it still comes on?
Old Oct 22, 2003 | 09:27 PM
xvracing's Avatar
yes,...several times.
Old Oct 22, 2003 | 09:28 PM
xvracing's Avatar
Default Re: mpfi swap complete...code 4 (skelly ed6)
Is there anyway to bypass the limp mode???
Old Oct 22, 2003 | 09:37 PM
EG8R's Avatar
Not that I know of. I'd say the dizzy is wacky if everything else is correct.
Old Oct 22, 2003 | 10:12 PM
JonGP4's Avatar
make sure the pins are in the ecu really good, i mean the actual pin itself the crank angle sensor is on pins b10, b12 org, wht. you need to check those! c1 and c2 are cyl position sensor thats something different, and will throw i different code..
Old Oct 22, 2003 | 10:42 PM
rags2riches's Avatar
i had the same problem before, when you hit the gas it hits 3000 rpms, then bogs, bogs, bogs, and doesnt go any higher,
check the tps sensor, make sure you reversed the wires as per spec, the green and yellow ones must be changed, also checkout you have no leaks on that new intake manifold and that its tight......checkout to make sure you have all the injectors in the right order - red/yellow/blue/brown, and the injector resistor box is properly wired in......
Old Oct 23, 2003 | 05:51 AM
jlicrx's Avatar
code 4 - usual suspects - camshaft timing is off or you have a bad distributor - OBD0 does not have a limp mode
Old Oct 23, 2003 | 06:01 PM
Tbone's Avatar
Had the same problem last week. It was the repin job on the ecu. Everthing looked ok but there wasnt connection on those pins. We replaced the dist and the cyl sensor before finding this out on us .
Old Oct 26, 2003 | 06:14 PM
bullock's Avatar
what motor do you have and what ecu ?
Old Oct 26, 2003 | 08:09 PM
skrappy's Avatar
i have the same problem i also need help
Old Oct 27, 2003 | 05:21 AM
EG8R's Avatar
Default Re: mpfi swap complete...code 4 (skrappy)
Um.... Hit it with a very large hammer....
vtec93accord
Apr 4, 2008 05:24 PM
91BlueEF9
Nov 1, 2007 10:53 AM
crx90rcr
May 1, 2005 11:23 AM
Hcivic88
17
Apr 27, 2004 09:23 PM
