My car has developed a really bad sputter. Help!
Just playing. But since I got you attention now....
My car has developed a really bad sputter. The car has a new dizzy, fuel filter and I recently replaced the main relay. The car is fine at idle and only does it at medium tthrough high throttle. until about 3k RPM. Any ideas guys? I'm stumped
TIA
TIA
This may sound simple, but have you checked your spark plugs and wires? My car had the same problem about a year ago. I changed the plugs, and it ran perfect.
I don't have a timing light right now, but the problem was present before the dizzy was replaced. I replaced it because the car wouldn't start and there was no spark. so I swapped the new one in. But I do plan on setting the base timing as soon as possible.
Hmmmmm...The car may be low. My GF said it started to overheat the other day. That is interesting. what affect would that have? Thanks for all the replies guys
Stupid titles like this don't get you as much help and basically make this thread dissapear so know one can ever find it using the search function. Thanks douche.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricodemus »</TD></TR><TR><TD CLASS="quote">Stupid titles like this don't get you as much help and basically make this thread dissapear so know one can ever find it using the search function. Thanks douche.
I was thinking the same thing. Now if somebody has a similar problem and they do a search they will never find it.
Awe c'mon no need for name calling. That's kinda harsh. I forgot this is the place of no fun or happiness. LOL you guys need to just lighten up. I was going to change the title figuring I would get more responses. Anyway keith already changed the title for me. so
j/p
j/p
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CamoHatch »</TD></TR><TR><TD CLASS="quote">Hmmmmm...The car may be low. My GF said it started to overheat the other day.
My lower radiator hose was leaking like a sieve awhile back. When the coolant got low, the car would bog at low RPM's, but it would run normally if I gunned it.
Added anti-freeze and the problem stopped...until the antifreeze got low again...
NatedoggAZ
May 26, 2004 05:20 PM
Anybody else?
i was gonna flame but i should be flamed for fallin for it
