need help please
Old Oct 22, 2003 | 07:31 PM
97coupe's Avatar
Default need help please
i have a 97 civic coupe (d18y8)and its been running funny this last 2 days its ideling at 2k rpm and i got a check engine light i went to check it out in auto zone it gave p018(engine coolant temp circuit high output) any ideas what is that mean will be really helpfull
Old Oct 22, 2003 | 07:36 PM
piscorpio's Avatar
Default Re: need help please (97coupe)
Here is the Helm's manual entry:
P0118 (6) Engine Coolant Temperature Circuit High Input
Possible cause: Open in ECT sensor circuit, ECT sensor, ECM/PCM
Hope this helps a little.
Old Oct 22, 2003 | 07:45 PM
97coupe's Avatar
Default Re: need help please (piscorpio)
thans, any other ideas?
Old Oct 22, 2003 | 07:51 PM
piscorpio's Avatar
I think that is pretty much it, check your engine coolant temp. sensor and go from there. You might just need a new one.
Old Oct 22, 2003 | 07:53 PM
97coupe's Avatar
u think from the temp sensor the ideal in 2k? and it keeps going up and down from 1.5 to 2k
Old Oct 22, 2003 | 08:26 PM
HXvtec's Avatar
cool ur in orlando. im in winter park. n e way he's right check the sensor
Old Oct 22, 2003 | 08:30 PM
hondafied's Avatar
Default Re: need help please (HXvtec)
the ect lets your car know when its warmed up enough to run in closed loop, so, if your ect is bad, your ecu will think that the caris never warming up, thus explaining your high idle. hondas ect's go out pretty often so try a new one. DONT GET AFTERMARKET THOUGH. If you cant afford it at a dealer hit me back cuz i wrok i a dealer and ill hoook you up. OEM parts like that will last a lot longer.
Old Oct 22, 2003 | 10:16 PM
Spartanic's Avatar
What they probably mean is the grounding next to the thermostat housing. If you look carefully you'll see 2 wires that are grounded together on the thermostat housing. If its loose then tighten it back up or take it off and clean the contact points. Sometimes if that grounding is loose or corroded then you would notice your engine idling badly, engine hard to start or the MPH needle jumping back and forth on the speedomoter. Hope this helps out!
Old Oct 23, 2003 | 12:16 AM
CARFX's Avatar
Default Re: need help please (Spartanic)
There's a valve with 2 wires in the left side of the engine head, check it out if there's no cut wire or something, or try to take out the valve and clean it...
Old Nov 13, 2011 | 06:53 PM
ekcivic0413's Avatar
did you ever find out what your idleing problem was? i have a 96 honda civic coupe and its ideling high but stays at one rpm. i need help :/
Old Nov 13, 2011 | 06:55 PM
Former User's Avatar
This is an 8 year old thread, so you should make your own thread.
dohcvtecpower
Sep 30, 2010 05:11 AM
95civicohyeah
Oct 26, 2009 06:14 PM
slammedz6ef
Jan 28, 2008 04:31 PM
Oreo-TeCk
May 21, 2007 09:39 AM
