Best size TB for my setup
Old Oct 22, 2003 | 06:31 PM
GT-KiLLa's Avatar
Default Best size TB for my setup
hers what im running
b18c block decked
LS rods
polished crank
CTR OS pistons
b18c head milled w/CTR internals
balanced and blueprinted
skunk2 manny
rc310 injectors
hondata s200 w/p28
current C/R is 12.9:1
whats a good size TB for this set up, i dont want to go too big because i hear that could be bad for the motor. any one got input on this?
thanks yo
Old Oct 22, 2003 | 06:34 PM
b19coupe's Avatar
Default Re: Best size TB for my setup (GT-KiLLa)
I would say in the neighborhood of 66mm.
Old Oct 22, 2003 | 06:35 PM
GT-KiLLa's Avatar
Default Re: Best size TB for my setup (b19coupe)
how much can i bore a stock TB from a gsr?
Old Oct 22, 2003 | 06:46 PM
b19coupe's Avatar
Spoon bores the 62mm ITR throttle body to 70mm, so I would guess that a 60mm GSR TB could be bored to around 68mm.
Old Oct 23, 2003 | 05:48 AM
Mr Hammond's Avatar
a/k/a Jomo
Well it's a tapered bore that ends up being the stock 62mm at the opening. I dont' think you could bore stock 70 all the way through. Most recomend about a 4mm overbore to be the most.
Old Oct 23, 2003 | 09:52 AM
TrboInteg's Avatar
Default Re: Best size TB for my setup (Mr Milano)
Mr. Milano is right, the spoon is a tapered bore that starts out as 70mm and ends at the stock ITR's 62mm.
If I recall correctly, there was a guy in the classifieds section offering his boring(<--haha) services. I think he could bore a GSR out to 64mm and an ITR out to 66mm. It was something close to that
Old Oct 23, 2003 | 05:20 PM
GT-KiLLa's Avatar
will i see much gain if i bore out my stock gsr tb? or should i just get an aftermarket one..like 65mm or 68mm?
Old Oct 23, 2003 | 08:28 PM
Waachback's Avatar
Default Re: (GT-KiLLa)
i have a 65mm gsr bored tb. Dident really do any good....
86si
21
Jun 12, 2007 02:44 AM
pornstar4777
May 17, 2006 01:24 PM
Junkyard2000
Sep 1, 2005 07:44 PM
logistixz
Jun 10, 2002 05:50 PM
