Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
what lugs with TL studs?
Old Oct 22, 2003 | 05:40 PM
whiteyg2rs's Avatar
Default what lugs with TL studs?
I ordered the TL studs for my '91 teg this week and I also wanted to get new lug nuts. I need to use the thinner "tuner lugs" with my wheels so I ordered a set of gorillas like these:
It never occurred to me though that these lug nuts might bottom out on the TL studs since they're longer. Do I need to have open ended lug nuts with these studs? Or will the gorillas work? TIA.
Old Oct 22, 2003 | 06:51 PM
Tyson's Avatar
Default Re: what lugs with TL studs? (whiteyg2rs)
they will work fine. actually perfect.
Old Oct 22, 2003 | 07:04 PM
DB2-R81's Avatar
25 Year Member
Default Re: what lugs with TL studs? (Tyson)
Hello Tyson,
How can you answer this without knowing the thickness or depth of lug holes in the wheel hub pad on his wheels?
Old Oct 22, 2003 | 07:21 PM
Tyson's Avatar
Default Re: what lugs with TL studs? (DB1-R81)
the thickness from the inner face to the lugnut seat is usually the same, at least for all 4 different wheels ive put on my crx. my TL studs and gorilla/mcgard lugnuts are the same dimensions as pictured, and thread in perfectly, leaving just about the exact space you see in those thin little end caps.
Old Oct 22, 2003 | 07:33 PM
DB2-R81's Avatar
25 Year Member
Hello Tyson,
Were all 4 wheels the same off set?
Old Oct 22, 2003 | 07:41 PM
Tyson's Avatar
nope, stock 45 to 36.
Old Oct 22, 2003 | 07:56 PM
Floyd's Avatar
FWIW, I use the TL studs with my Kosei K1's and I was able to use a "long" closed-ended lug I bought at Advance Auto. I have since replaced them with open-ended lugs, but I would imagine the McGuards will work fine.
Old Oct 22, 2003 | 08:40 PM
Mike_C's Avatar
Forgive me for my ignorace but what's the advantage to using TL studs?
Old Oct 22, 2003 | 09:01 PM
Tyson's Avatar
Default Re: (JMU1337)
about 1 cm extra length, oem fit and quality and relatively cheap. you missed the big wheel stud thread?
Old Oct 22, 2003 | 09:32 PM
Mike_C's Avatar
Guess I'm not as studly as thou... mwahaha
I didn't really care about tech til I got my hatch this past year, so yeah I probably overlooked the thread.
Old Oct 23, 2003 | 02:46 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (Tyson)
TL? Try 86-89 Tegs rear lugs!!!!!!
You think this info is new???????
Old Oct 23, 2003 | 04:47 AM
whiteyg2rs's Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">TL? Try 86-89 Tegs rear lugs!!!!!!
You think this info is new???????</TD></TR></TABLE>
I saw you mention that in THE "wheel stud thread". They had the same part number as the rear TL's and cost the same at acuraautomotiveparts.org. But you get more of a cool factor using parts off a TL than a gen1 teg.
Anyways, now that we've established I'm a ricer, thanks for the info Tyson. I was a little worried there for a minute that they wouldn't fit.
BLK2DOOR
Apr 13, 2010 09:36 PM
WhiteDc4Integra
Jan 16, 2010 03:26 PM
alexsracing
Oct 20, 2006 09:14 AM
alexsracing
Oct 19, 2006 11:04 AM
civicrights
Oct 16, 2003 05:48 PM
