hatch is leaking!!!
Old Oct 22, 2003 | 11:24 AM
yusoslo's Avatar
Default hatch is leaking!!!
My car is leaking when it rains in the back hatch. THe car was once in a wreck and a new quater panel was tacked in but not seam welded. i removed the rain gutter and the interior and but silicone in there but water seems to still slowly find its way in. Has anyone had this problem before???
Old Oct 22, 2003 | 12:28 PM
hayabusa160's Avatar
Default Re: hatch is leaking!!! (yusoslo)
would this be an ek hatch? just woundering
Old Oct 22, 2003 | 12:44 PM
yusoslo's Avatar
Default Re: hatch is leaking!!! (hayabusa160)
sorry it is an EG and it is not from the tailights
Old Oct 22, 2003 | 12:53 PM
Cookie's Avatar
How's the rubber around the window?
Old Oct 22, 2003 | 12:57 PM
Dancing is Forbidden's Avatar
Default Re: hatch is leaking!!! (Cookie)
mine was leaking from a missing grommet up in the rear spoiler check there.
Old Oct 22, 2003 | 01:02 PM
Cookie's Avatar
Default Re: hatch is leaking!!! (EF9_SiR)
Crazy how one freakin grommet can cause a leak!
Old Oct 22, 2003 | 01:51 PM
yusoslo's Avatar
the window grommet is perfect. I poured water all over the place. What is coming from is the rain gutter. There were holes where he tack welded the quater panel in. I filled those with silicone to be sure, maybe i missed a spot, but the water leaks from the middle of the rear window, and not the window seal, but actually from the roof above it. What kind of place could do this? I need to fix it and am tired of the musty smell, and I dont want to take my head liner off myself
Old Oct 22, 2003 | 08:37 PM
yusoslo's Avatar
Old Oct 22, 2003 | 08:51 PM
solo2slocivic's Avatar
pull the headliner and do you water test again... when u zero in on the exact place fix it... it is not hard to do i do it every winter/spring at work jst go to a body/paint supply shop..... you need to use some body sealant or urethane and make sure you clean the surface really good... the body shop didnt do that very well....
Old Oct 22, 2003 | 08:53 PM
Mr Boston's Avatar
Default Re: (solo2slocivic)
Does anyone know what exactly what sealant honda use for the seams under the rain gutters?
Old Oct 22, 2003 | 08:55 PM
we use a 3m seal sealant would have to look at the tube tomorrow to tell you what number it is
Old Oct 22, 2003 | 08:57 PM
Mr Boston's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo2slocivic &raquo;</TD></TR><TR><TD CLASS="quote">we use a 3m seal sealant would have to look at the tube tomorrow to tell you what number it is</TD></TR></TABLE>
Thanks alot..
Old Oct 22, 2003 | 09:03 PM
yusoslo's Avatar
Default Re: (Ngo Power)
thanks for the replys, I am glad it doesnt need to be welded.
PS how hard is it to remove all the old gunk, becuase the previous guy did put this black tarish stuff under the rain gutter. I guess take a putty knife to it???
btw my car is in the primer stage so no need to worry about scratching the paint
WeakSauce92
13
Jul 16, 2010 01:26 PM
lancerkid06
Mar 6, 2009 08:27 AM
CRXDaddy78155
Jul 7, 2007 04:05 AM
drew2
Jul 23, 2006 10:08 PM
sxecustoms
May 31, 2003 02:30 PM
