1991 SiR prob
Hi, i have a 1991 SiR.
Problem is there is a slight knocking coming from the front wheel area when going over rough ground. I can feel it through the steering wheel.
I have only heard this from inside the car, kinda clunking noise.
It's just started in the last few days.
Any ideas??
Any ideas??
I had the same prob with my car, and it turned out to be loose upper arm joint bolts...the ones that bolt the arm to the bushings. Mine were a little loose when I was going to install camber kits....check those bolts....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL_Vap133 »</TD></TR><TR><TD CLASS="quote">It might also be a blown strut...
I have coilovers man-they should be fine. Could it be a track rod end or bushes?
</TD></TR></TABLE>I have coilovers man-they should be fine. Could it be a track rod end or bushes?
John, check the bushes, check the track rod ends, and check the upper arm bolts!
i had the same prob on my old si-R, it was the upper arm joint bolt lose!
Ifs its a "metallic" clunking, it dont think it wil be the bushes, thats more of a "thudding "type sound
Dan!!
Dan!!
Spoon*EK9
Aug 14, 2008 07:41 PM
em96civicex
13
Feb 19, 2008 10:03 PM
