itr rear lca's thicker?
Old Oct 22, 2003 | 08:46 AM
an2ny888's Avatar
Default itr rear lca's thicker?
can anyone confirm that the itr rear lca's are thicker than regular integra's? i read that it was over in the civic forum and wanted to know if its true
Old Oct 22, 2003 | 09:03 AM
Todd00's Avatar
I said I don't want a title!
Default Re: itr rear lca's thicker? (an2ny888)
What do you mean 'thicker'?
Material isn't any thicker, but the way the shock mounts into it makes the ITR/88 CRX control arm wider than the normal piece o' crap Integra/Civic LCA.
Old Oct 22, 2003 | 09:27 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">can anyone confirm that the itr rear lca's are thicker than regular integra's? i read that it was over in the civic forum and wanted to know if its true</TD></TR></TABLE>
definitely heavier, so there's more metal there somehow.. I personally haven't had two side by side to compare though..
Old Oct 22, 2003 | 09:54 AM
cheezthis's Avatar
Default Re: itr rear lca's thicker? (mstewar)
The Integra GSR/LS lca is a lot heavier.
The ITR lca is bigger, but lighter. If hold the two side by side...you'll see why simply by the design.
Old Oct 22, 2003 | 10:10 AM
Vitt1's Avatar
Default Re: itr rear lca's thicker? (Todd00)
Todd00, I've always wondered what's the advantage. Are they less likely to flex with that construction design?
Old Oct 22, 2003 | 11:13 AM
mstewar's Avatar
Default Re: itr rear lca's thicker? (cheezthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheezthis &raquo;</TD></TR><TR><TD CLASS="quote">The Integra GSR/LS lca is a lot heavier.
The ITR lca is bigger, but lighter. If hold the two side by side...you'll see why simply by the design.</TD></TR></TABLE>
i was told the opposite.. now i have to test..
Old Oct 22, 2003 | 11:25 AM
cheezthis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
i was told the opposite.. now i have to test..</TD></TR></TABLE>
I'd take a picture if I wasn't busy right now. The ITR lca's are not solid all the way through like the GSR ones...if that makes sense. Hint, look at the ITR lca from below.
. o 69 o .
Sep 9, 2003 06:03 PM
integlspwr01
Aug 4, 2003 11:02 PM
fuguman
Aug 27, 2002 02:04 PM
Mr. Softee
Jun 13, 2002 02:16 PM
