apex'i N1 exhaust question
Old Oct 22, 2003 | 08:46 AM
BassBoy19's Avatar
Default apex'i N1 exhaust question
can I just install the rear section of the cat back on my stock ITR ? will the apex'i flange fit the stock honda flange ? thanks...
Old Oct 23, 2003 | 10:25 AM
BassBoy19's Avatar
come on guys and girls, I really need this answer...
Old Oct 23, 2003 | 11:56 AM
Nuts's Avatar
Default Re: (BassBoy19)
this is not answer to your question but stock ITR axle back can be install with Apex'i B-pipe. Someone on here has done it before...
Old Oct 23, 2003 | 03:00 PM
TypeRPaul's Avatar
Default Re: (01-1194)
i dont see why it wouldn't i just put my stock muffler on my apexi back section to get a fix it ticket signed off.....btw if you are putting the apexi muffler on your itr you will need to remove the 4 bolts that hold the rear sway bar bushings in place to get the pipe through...its kinda a bitch but ya have to do it
Old Oct 23, 2003 | 04:34 PM
sackdz's Avatar
Default Re: (TypeRPaul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRPaul &raquo;</TD></TR><TR><TD CLASS="quote">btw if you are putting the apexi muffler on your itr you will need to remove the 4 bolts that hold the rear sway bar bushings in place to get the pipe through...its kinda a bitch but ya have to do it</TD></TR></TABLE>
I never had to...
Old Oct 23, 2003 | 05:02 PM
py1188's Avatar
Default Re: (sackdz)
They will not fit perfectly, they need some modification if I remember correctly. I believe one is longer or something, but dont quote me on that
Old Oct 23, 2003 | 05:07 PM
paRRRker's Avatar
Default Re: (py1188)
im not sure but i think there is a little difference in piping size...and yes i also believe one is longer than the other but im not posative either.
Old Oct 23, 2003 | 07:21 PM
MiraiZ's Avatar
Default Re: (Hype-aaaRRRR)
I believe the only difference was the shape of the flange...you will need some kind of gasket...
Old Oct 24, 2003 | 09:25 AM
BassBoy19's Avatar
looks like a pain in the *** for the 0.000005 HP I will gain versus my current brospeed str8 muffler....thanks guys for the info
jim9
Sep 16, 2008 04:52 PM
OEMaccord96
Dec 8, 2003 03:52 PM
Nuts
Nov 18, 2003 12:16 PM
Leo
Nov 28, 2002 10:24 PM
itr501
Jul 4, 2001 06:02 PM
