What should i use??????????
Im running a 94 Civic with a JDM B16a1 in it. I'm looking to run as fast as possible in the quickest time period. You guys think i should run Nitrous or put new cams and cam gears in it....any help is good!!!!
For what application? You can go fast on Nitrous but will blow your motor up pretty fast too. Putting cams & gears, good tuning, will work but again, they're not the fastest set up...If money is not a problem...just get yourself a fully built turbo charged motor swap that includes everything to make it work, drop it in and call it the day. Same goes if you want an all motor set up too. It will take you no more than a week to get this done if you have the motor ready and of course $$$.
OK, but if i only spray 50 shot then i shouldnt have to really worry about blowing my motor should I (I dont plan or spraying every day) But i'm just looking to smoke my freinds acura!!!!! and he just barely pulls me!!!!
hondatuner20
Jul 13, 2006 04:50 PM
