zc vs d16a6 crank question
Old Oct 22, 2003 | 04:22 AM
APEXI Si's Avatar
Default zc vs d16a6 crank question
The tie down braket. Not sure the exact name of it.. but it is the long metal piece thats holds the crank down. Will one from a zc work on a A6. Thanks for all your help if you have info.
Old Oct 22, 2003 | 04:23 AM
APEXI Si's Avatar
Default Re: zc vs d16a6 crank question (crx616)
bump
Old Oct 22, 2003 | 05:09 AM
keithv's Avatar
I think you are referring to the Main Cap. Is it the "bracket" pictured on the bottom right of this picture (the one with the bolts shown that go through it)?
Old Oct 22, 2003 | 07:15 AM
APEXI Si's Avatar
Default Re: zc vs d16a6 crank question (keithv)
yes that would be the one. Is the bracket on a ZC the same as a a6?
Thanks for clearing that up for me Keithv
Old Oct 22, 2003 | 08:00 AM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx616 &raquo;</TD></TR><TR><TD CLASS="quote">yes that would be the one. Is the bracket on a ZC the same as a a6?
Thanks for clearing that up for me Keithv</TD></TR></TABLE>
From what I can tell, the Main Cap girdle on both the ZC and A6 are the same. The oil pickup, which mounts to the Main Cap, are the same for the ZC and A6.
Old Oct 22, 2003 | 09:02 AM
APEXI Si's Avatar
That is great... thank you..
Can anyone else confirm this to be ture
Man keithv you are the man today.
thanks again
Old Oct 22, 2003 | 09:47 AM
Garrett's Avatar
Main cap aren't the same, pick up is the same.
The main cap from d16a6 are made of steel and the top plate is aluminum. The ZC one is all made of aluminum. Is you project to put the d16a6 main cap on the Zc you'll have to machine the cap to use the same bearing as the block. I'll post you pics off the 2 différent main in a couple of hours.
Old Oct 22, 2003 | 09:54 AM
APEXI Si's Avatar
Default Re: zc vs d16a6 crank question (Garrett)
the plan is to put the zc main cap on the a6
Old Oct 22, 2003 | 12:24 PM
1990civicsiguye's Avatar
something on the topic.. Are the cranks themselves the same 90 si and say 90 zc?
Old Oct 22, 2003 | 12:52 PM
SuperJay's Avatar
Default Re: (1990civicsiguye)
I don't think it'll work because the bearing caps and block are bored together as one. if you mix and match blocks and bearing caps from different motors the caps may bolt in but as far as the bore, they won't match. You could do a little figurin with the bearings prolly, but the top and bottom bearings will most likely be different for each journal. But good luck though
Old Oct 22, 2003 | 01:03 PM
4drEF's Avatar
Keyboard Humorist
Default Re: (SuperJay)
Couldn't he just calcualte what bearings are needed but putting the cap on without a crank and measure the journal diameter and then measure the diameter of the crank.
Old Oct 22, 2003 | 05:51 PM
MrTodd's Avatar
Default Re: (4drEF)
It still could be off... You'd really have to measure the journals - even so, they could still be oblong or something like that. Simply mixing/matching the bearings might not do it. You're much better off sticking with the girdle designed for the block.
Old Oct 22, 2003 | 07:03 PM
jlicrx's Avatar
take it to a machine shop and have it align bored or honed, as required, with the ZC main caps
Old Oct 23, 2003 | 02:41 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: zc vs d16a6 crank question (jlicrx)
whenever you swap the maincaps from one block to another, the block+cap must be alignbored and honed.
Old Oct 23, 2003 | 05:20 AM
SIRX's Avatar
Default Re: zc vs d16a6 crank question (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">whenever you swap the maincaps from one block to another, the block+cap must be alignbored and honed.</TD></TR></TABLE>
W3Rd I was thinking the same damn thing about the time I got to the 3rd reply. At least there are other smart peeps
Old Oct 23, 2003 | 06:11 AM
APEXI Si's Avatar
Default Re: zc vs d16a6 crank question (SIRX)
Thanks guys. but what about the half moons that look almost like rod bearings that are on the main cap.. do i replace those and still get it bored and honed. Would not doing that cause the crank to rotate off balance or cause excess heat.
School me guys i am looking for some education.
thanks
Old Oct 23, 2003 | 08:26 PM
SuperJay's Avatar
you must be talking about the thrust washer. That's for end play on the crank. I think those are pretty musch standard for D-series. I could be wrong though.... anyone?
ninty1civic
Nov 29, 2010 07:32 AM
bokamper17
Oct 5, 2009 07:22 AM
tyler100
Nov 3, 2008 08:21 AM
DarkSol97
Jul 8, 2006 02:36 PM
90wagon4wd
Jan 9, 2004 06:01 AM
