Quality of DC 4-1 header?
Old Sep 3, 2001 | 05:07 PM
EleanoR's Avatar
Default Quality of DC 4-1 header?
Is the quality of this header decent? It is not the JDM version. Would the JDM version be much more beneficial than the regular CC header? Any info would be greatly appreciated. Thanks,
Mike
Old Sep 3, 2001 | 05:09 PM
Back in Black's Avatar
Rather OG
Default Re: Quality of DC 4-1 header? (talkie25)
What are your plans for future modifications?
Old Sep 3, 2001 | 05:15 PM
Mike K's Avatar
Default Re: Quality of DC 4-1 header? (Darth VadeR)
In all honesty, I wouldn't waste your time with the regular DC header. I've seen the stock US ITR exhaust manifold make more power than a US DC header on more than one occasion on the dyno. Take it off, and separate the two pieces. Open the ports on the upper piece, and smooth it all out with a 6" extension jagged ball piece on a air tool. I forget the proper name for it, but you know what I am talking about. Then clean up the nasty welds on the bottom piece where the two round gaskets are. Make sure that the upper four ports are the same in size, and *slightly* larger than the exhaust port on the head.
With these modifications, you'll probably gain a solid 2 or 3 hp no problem. I've seen it with my own two eyes on my friend Mike's motor(B18C5 w/ 12:1 Rollerwaves).
-Mike k
Old Sep 3, 2001 | 05:16 PM
EleanoR's Avatar
Well my plans right now (to buy all at once and install as i find the time): AEM CAI, Comptech Lightened flywheel, AEM cam gears, VAFC, maybe some custom exhaust work to rid the bottlenecks and of course dyno tuning at the end
Mike
Old Sep 3, 2001 | 05:34 PM
Bob#455's Avatar
I would recommend that you get a JDM Honda 4-1 and a high flow cat to bolt up to the stock exhaust...then get rid of the bottlenecks in the b-pipe. If you do that, you should notice some gains...if you get a USDM DC and keep the stock cat, I don't think you'll gain anything. Hope this helps.
Old Sep 3, 2001 | 05:40 PM
EleanoR's Avatar
Default Re: Quality of DC 4-1 header? (Bob#497)
What if i ditched the header idea and just kept the OEM equipment??? I mean i would have the OEM header, high flow cat (probably carsound), and some custom exhaust work to rid bottlenecks. How does that sound? Is the header really needed???
mike
Old Sep 3, 2001 | 05:42 PM
nsx-Animal's Avatar
Don't spend your money on the US DC header get the JDM version. You will get a lot more power with a High Flow cat. The DC header is rip off the MUGEN 4-1 header. Obviosly not as nice
Old Sep 3, 2001 | 05:54 PM
Bob#455's Avatar
mike
I'm no expert, but I would say your aren't going to notice much at all with just the high flow cat and modified stock exhaust.... I think getting the JDM 4-1 is worth it in your case.
Old Sep 3, 2001 | 06:04 PM
SwiftTypeR's Avatar
New User
from someone who has actually dyno'd both the dc sport header and a jdm 4-1, i would say it depends on how much mods your planning on doing. if your sticking with the basics, i/h/e, get the dc sport. it'll be alot cheaper and u'll get more hp. if u plan on doing cams or any headwork then get the jdm which would make more hp.
Old Sep 3, 2001 | 06:53 PM
chad's Avatar
Moderator
if you get a new flywheel do a new clutch too....don't put a used one back in especially a stock one...unless your aftermarket clutch has few miles on it!
Old Sep 4, 2001 | 04:52 AM
EleanoR's Avatar
Default Re: Quality of DC 4-1 header? (chad)
I thought there were several guys on this board who had the CompTech aluminum lightened flywheel on their R's with the stock clutch. They said they had no problems if i remember correctly.
Mike
Lil Corb
Jan 17, 2005 01:01 PM
Dynamix
Mar 26, 2003 10:05 PM
cichlid
Mar 22, 2003 12:51 PM
lewylou
Jan 21, 2003 05:43 AM
acatak
May 13, 2002 05:32 PM
