New Dyno results with fixed compression
Well, got some new numbers, not what I hoped for, but better none the less. 200.0 hp and 137.9 ft-lbs. Once again, the HP curve is flat from 7800-8600. Not sure what caused that, we are guessing the t-body.
I have 130+ ft lbs of torque from 5800-7800. 135+ ft-lbs from 6400-7700.
Not sure why the curve is leveling off again. We think it may be the t-body not supplying enough volume for the car now. No idea, but at least it is not something that HAS TO BE FIXED. This next mod can come when I am ready.
All runs today were done with the full exhaust. I will go back at a later date to run with the open header. Should be good for a few hp.
Well, we will see what times it can run soon...
Jason
Jason
Banned
From: at last finally back to sweet home, sunny north cali, usa
so what was the cause of the low compression? was it valve lashing? improvement sounds good. in your previous post you mentioned 194 hp and 129 ft-lbs... so it's a pretty nice bump.
Intake valves were beat to hell. Looked like some kid had taken them out, played with them on the concrete, and scarred up all the edges.
Jason
Jason
acura_b18c1
21
Oct 8, 2009 11:42 AM
