What axles are you using for all motor with 25" Slicks ?
Old Oct 21, 2003 | 07:33 PM
anlia's Avatar
Default What axles are you using for all motor with 25" Slicks ?
Anybody can share your experiences ?
Which axles will work best with all motor with 25" Slicks : DSS Stage ? ; Prodrive Stage 1 ; TCI Stage 3 ; Enjo Stage 3 or Drive Shaft shop ?
Thank you .
GOD BLESS U
Modified by anlia at 5:58 AM 10/22/2003
Old Oct 22, 2003 | 02:17 AM
kwik93si's Avatar
Default Re: What axles are you using for all motor with 25" Slicks ? (anlia)
enjo's suck man...my buddy's crx runs 11.3's and he just started running enjo axles, and he's breaking them like crazy...he's breaking them off the line, in 2nd gear, and he's even broke shifting into 4th.
Old Oct 22, 2003 | 05:39 AM
Bisimoto's Avatar
Default Re: What axles are you using for all motor with 25" Slicks ? (kwik93si)
TCI for me. I use the 500+. Overkill, but I like it.
Old Oct 22, 2003 | 06:16 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anlia &raquo;</TD></TR><TR><TD CLASS="quote">Anybody can share your experiences ?
Just curious if you've tried the OEM ones first before going to aftermarket ? I've done many times, btw &lt;knock on wood&gt; clak clak clak, no breakage evne with twin disc clamping force.
Greg
Old Oct 22, 2003 | 08:42 PM
anlia's Avatar
How about DSS Stage 3 or Stage 5 ? Which one will be better for all motor applications ?
GOD BLESS U
Old Oct 22, 2003 | 09:11 PM
4piston's Avatar
How much power are you making to turn those 25s and what does the car weigh?
Old Oct 22, 2003 | 09:41 PM
anlia's Avatar
Default Re: What axles are you using for all motor with 25" Slicks ? (4piston)
Around 270 Hp ( Bore 85.5 x Stroke 94 ) and 1800 lbs .
GOD BLESS U
Old Oct 23, 2003 | 05:54 AM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anlia &raquo;</TD></TR><TR><TD CLASS="quote">Around 270 Hp ( Bore 85.5 x Stroke 94 ) and 1800 lbs .
GOD BLESS U</TD></TR></TABLE>
whp
??what kinda setup?
Old Oct 23, 2003 | 07:26 AM
SpoolnG2's Avatar
Default Re: What axles are you using for all motor with 25" Slicks ? (GOLDBERG)
DSS stage 3's are good for 500hp. they come with the axle and a new hub. $1,000 for the set. those should be sufficient. and they come with a 1 year warranty. its what i've got.
Old Oct 23, 2003 | 08:50 AM
snowseeker's Avatar
OEM will be fine..
Old Oct 23, 2003 | 01:37 PM
ParrisEngineDynamics's Avatar
Default Re: What axles are you using for all motor with 25" Slicks ? (snowseeker)
I'm sure there is not too many all motor people on this board who use 25" slicks haha..... I'm sure OEM will not work out too well.
Old Oct 23, 2003 | 08:40 PM
anlia's Avatar
My Current set-up was Honda B 18C Block with Bigger Bore to 85.5 mm ( Wiseco Pistons ) and 94 mm Stroke , this is the JUN Crankshaft that comes in JUN 2 Liter Kit ( 82 mm x 94 mm ) . Most of the Japanes tuners only goes 94 mm in Stroke ( JUN and Spoon and etc .
GOD BLESS U
Old Oct 23, 2003 | 08:51 PM
speedyonez's Avatar
How many RPM will you be reving this monster too?
Old Oct 23, 2003 | 09:01 PM
anlia's Avatar
Default Re: (speedyonez)
Around 9 K RPM
GOD BLESS U
Old Oct 26, 2003 | 07:19 PM
anlia's Avatar
Default Re: (anlia)
Anybody using 25" Slicks in All Motor Class can help me to decide which axles to use ?
GOD BLESS U
nodnarb660
Sep 5, 2006 09:28 AM
krazy one
Mar 6, 2006 12:24 AM
jdmoutlaw
Aug 19, 2004 11:19 AM
Jdm_Rice_Monster
Feb 4, 2003 05:53 AM
