pic request of lines through firewall
i searched and didn't find much. where did u guys run your lines for your boost gauges, oil psi, watertemp, amplifier positive line ect.
if u have a pic post it up and help me out with some ideas.
i will have a water temp, oil psi, boost/vac and an amp line to run.
thanks in advance.
oh i need them for a 92-95 civic.
thanks in advance.
There are several spots on the fire wall that already have wires running through them or you can make a custom hole. I used an existing one already there.
It's actually MUCH easier to make your own hole (fit to size) and find a grommet for it. It's a pain in the *** using the ECU/dash holes in the firewall when trying to pass anything bigger than 1 wire through.
look underneath your battery.. you are bound to find atleast 2 spots to run wires.. you can run it next the a/c drop off tube if you have a/c if you dont, you should have a black grommet there..
i Got my Nitrous line running through where the Engine harness goes to the ECU.
I got all the rest of my **** running through where my cruise control used to be.
B20EF
Apr 29, 2009 01:49 PM
