why pr3 head instead of gsr 4 integ type r
Old Oct 21, 2003 | 06:35 PM
pootie.teng's Avatar
Default why pr3 head instead of gsr 4 integ type r
yo anyone knows why honda picked the pr3 head over the gsr head for the integra type r? i'm just wondering cause i need to know which head to use for my ls/vtec...
Old Oct 21, 2003 | 06:39 PM
esponet's Avatar
they did not want to use the gsr manifold, and rather use the lighter single plenium manifold,
different in combustion and intake runners,
if your leaving your stock buttom alone and not boosting then your better of using the gsr head, so you have a higher comp. ratio.
Old Oct 21, 2003 | 06:45 PM
Default Re: (esponet)
bottom end is completely built with gsr girdle, eagle rods, and 11.0:1 pistons. but hey i heard the gsr head flows better then the pr3 head and makes more power. can't i just mill the head down to get better compression?
Old Oct 21, 2003 | 07:45 PM
vtec.dc2's Avatar
Default Re: (teckno_geek)
more combustion volume?
Old Oct 21, 2003 | 09:22 PM
esponet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teckno_geek &raquo;</TD></TR><TR><TD CLASS="quote">bottom end is completely built with gsr girdle, eagle rods, and 11.0:1 pistons. but hey i heard the gsr head flows better then the pr3 head and makes more power. can't i just mill the head down to get better compression?</TD></TR></TABLE>
11:1 comp. ratio using which head, before you did all this you should have decided on which head to use, as the combustion chamber is different on both heads, deppending on piston p72 head might not work for you.
which head flows better? that is an argument that will never end, imo it all depends on whos porting the heads, tunning the motor.
i personally like pr3 heads,
Old Oct 22, 2003 | 12:09 PM
AzG35's Avatar
The type R head flows better than a GSR head. A stock PR3 head, is better in some spots, but the GSR head seems better at higher lift.
Capt. Jimbo McSubipants
13
Nov 29, 2005 01:36 PM
searching
Apr 10, 2005 05:11 AM
Chonger1
Jan 28, 2004 12:32 PM
Petah
Oct 27, 2001 09:19 AM
itr1236
Jul 14, 2001 09:32 AM
