should I not race because of axle???
Old Oct 21, 2003 | 06:18 PM
made in JAPAN's Avatar
Default should I not race because of axle???
the boot ripped recently (about 500 miles ago) on the inner joint of the drivers side axle. I am supposed to go to the track this weekend for the first time. I am running a 92 DA LS/VTEC. Do i have to worry about the axle breaking, will it be weaker?? if it is ok to race how do you suggest i launch??
Old Oct 21, 2003 | 06:36 PM
saso
Guest
Posts: n/a
Default Re: should I not race because of axle??? (made in JAPAN)
If the boot broke you may leak out your grease or contaminate your bearings. Pull them down inspect regrease and replace boot.
Old Oct 21, 2003 | 09:02 PM
hybridEj6's Avatar
Default Re: should I not race because of axle??? (saso)
my boot came off a while ago...when i first did my swap.......i just regreased and put a hose clamp on the end of the boot that came off and i was ready to go....i havent had any problems.
Old Oct 21, 2003 | 09:48 PM
Foozball26's Avatar
Default Re: should I not race because of axle??? (ekhybrd)
also, if anything is leaking don't race b/c you may leak on the track making it unsafe for yourself and others, the unsafe part for you is all the mad racers comming to get ya
B18CivicEH2
Mar 19, 2007 03:13 PM
bab33face
Oct 22, 2006 01:45 PM
Keewun
Dec 20, 2004 04:21 AM
abeaujuin
Sep 29, 2003 11:08 AM
davidbui
Jan 13, 2002 04:17 AM
