* List your head setup or dream setup
Old Oct 21, 2003 | 02:07 PM
jeremy.'s Avatar
Default * List your head setup or dream setup
curious to see what cams and valvetrain you guys are using....also what you guys would want to use
Old Oct 21, 2003 | 02:10 PM
skribblah's Avatar
Default Re: * List your head setup or dream setup (ek_jeremy)
EF-1 M22 cams & EF-1 aliminum retainers & EF-1 valvesprings.
Old Oct 21, 2003 | 03:31 PM
631 Teggy's Avatar
Default Re: * List your head setup or dream setup (skribblah)
Stil in the process of buying these parts:
All skunk2 valvetrain, skunk2 stage 2 cams, skunk2 stainless steal valves. And skunk2 cam gears of course... Still contemplating a 3 angle valve job... Dunno if it's worth it for a daily driver tho...
Old Oct 21, 2003 | 03:37 PM
jeremy.'s Avatar
Default Re: * List your head setup or dream setup (631 Teggy)
why wouldn't a 3 angle valve job be daily driven????
Old Oct 21, 2003 | 03:48 PM
631 Teggy's Avatar
lol no it's good... I just don't know if i would want to spend my money on it just yet... (a working college student).... So at this point i'd rather spend the money on some JE slugs...
Sorry for the confusion...
Old Oct 21, 2003 | 05:51 PM
Chas's Avatar
Portflow Springs, Retainers, Ferrea Valves, Spoon Gears, Spoon cams, Mugen headgasket.
Old Oct 22, 2003 | 05:28 AM
TGUNNER's Avatar
Skunk2 Stage 2 cams, Valvesprings, Retainers and Cam gears. Ferrea Stainless .5mm oversize valves and and a Cometic 84mm Custom Head Gasket..
Old Oct 22, 2003 | 07:25 AM
-KangaRod-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">at this point i'd rather spend the money on some JE slugs...
more power in the head IMHO
Old Oct 22, 2003 | 08:39 AM
631 Teggy's Avatar
Default Re: * List your head setup or dream setup (-KangaRod-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- &raquo;</TD></TR><TR><TD CLASS="quote">
more power in the head IMHO</TD></TR></TABLE>
but to get the most power out of the cams I'm ganna need some higher compression pistons
Old Oct 22, 2003 | 08:58 AM
MaxBoost's Avatar
New User
K20a Head
Port & Polish
HyTech Intake Manifold
HyTech Ti Retainers
HyTechDual Valvesprings
HyTech Stage 4 Drag Camshafts
HyTech Big-tube Header
72mm RPM Throttlebody
K24a Block
GE Sleeves
GE Deckplate
GE Electric Water Pump
89mm CP Pistons
Custom Carillo Rods
Balanced and Blueprinted
Stock K24 Crank
ARP Rod & Head Bolts
Old Oct 22, 2003 | 03:09 PM
JBk24crx's Avatar
skunk2 cams and cam gears protflow valvetrain.
Old Oct 22, 2003 | 04:05 PM
boondockgtr's Avatar
Default Re: * List your head setup or dream setup (MaxBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost &raquo;</TD></TR><TR><TD CLASS="quote">K20a Head
Port & Polish
HyTech Ti Retainers
K24a Block
GE Sleeves
GE Deckplate
89mm CP Pistons
Custom Carillo Rods
Stock K24 Crank
ARP Rod & Head Bolts</TD></TR></TABLE>
yeah, what he said!
What do ya'll think the best SOHC setup would be?
Old Oct 22, 2003 | 09:47 PM
RS_H22's Avatar
Default Re: * List your head setup or dream setup (boondockgtr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boondockgtr &raquo;</TD></TR><TR><TD CLASS="quote">
talk to Matt at Speed Machine, hes got a 1.5L making 181 WHP runnin mid 12's...
Bisi's F22 is making well over 300WHP , Id say what hes got would probably be the best...
Modified by RS_H22 at 6:59 AM 10/23/2003
Old Oct 22, 2003 | 10:07 PM
jeremy.'s Avatar
Default Re: * List your head setup or dream setup (RS_H22)
thanks rick....good looking out. looking foward to the dynos. vince's **** is still fucked..he hasn't even touched it. me and josh came to a conclusion that his car is cursed
Old Oct 22, 2003 | 10:49 PM
Daysleeper's Avatar
I know who is going to build my motor when the time comes
Old Oct 23, 2003 | 07:19 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">curious to see what cams and valvetrain you guys are using....also what you guys would want to use</TD></TR></TABLE>
dream setup ? pneumatic valvetrain in b-series head with custom camshaft and intake induction... can you say 15K rpms ?
Old Oct 23, 2003 | 07:26 AM
jaydmcrx's Avatar
hf motor with a sick moose antler wing. And hydrolics, With a batmobile body kit.
Old Oct 23, 2003 | 08:27 AM
Ronin Panda's Avatar
Default Re: (jaydmcrx)
JUN III cams..on the way
skunk 2 retainers.....have
skunk 2 valve springs...on the way
JUN cam gears......have
spoon headgasket....have
spoon 65mm t/b..on the way
twm itb/s with carbon fiber or just silver air horns..i have skunk 2 manifold
spoon 4-1 header..i have dc sports 4-1 itr
toda timing belt..on the way
skunk 2 high comp valves..on the way
dont know whos gonna do the machine work yet
Old Oct 23, 2003 | 11:10 AM
RS_H22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">thanks rick....good looking out. looking foward to the dynos. vince's **** is still fucked..he hasn't even touched it. me and josh came to a conclusion that his car is cursed</TD></TR></TABLE>
Next time I come down there Ill set aside some time and pull Vinces head off
Old Oct 23, 2003 | 11:26 AM
jeremy.'s Avatar
everyone thinks it's a spun rod bearing...the car is at josh's house sitting there
Old Oct 23, 2003 | 01:15 PM
advanracing62's Avatar
I don't have a "dream setup".. things change too fast to settle on one part or manufacturer.
Old Oct 29, 2003 | 01:04 AM
jeremy.'s Avatar
up
preludedriva
Sep 8, 2007 10:57 PM
thatwhiteguy
Apr 2, 2007 10:00 PM
pootie.teng
Dec 21, 2006 08:11 PM
hyrolnpimp
24
Mar 24, 2004 12:52 PM
DD_JonnyLee
Jan 10, 2003 04:07 PM
