which clutch to use with 98 D16y7 paired with 91 Civic Si tranny going into 91 civic dx hatch
The title pretty much describes my question, I want to order a new exedy clutch kit for this setup before i put it into my 91 civic hatch dx
i have a 98 D16y7 and am using a 91 civic si cable tranny, which year and engine clutch kit should i order? in other words, what will work? do i need the 98 d16 clutch kit, or the 91 civic dx clutch kit? then again, they are probably interchangeable, but i was looking for reassurance before i go ahead and order and install
thanks HT civic crowd!
YOU CAN USE EITHER CLUTCH SET, BUT ALL PIECES HAVE TO BE ONE OR THE OTHER. IN OTHER WORDS, WHATEVER FLYWHEEL U USE, USE THE CLUTCH SET THAT GOES WITH THAT FLYWHEEL. BUT USE THE RELEASE BEARING THAT MATCHES THE TRANNY. HOPE THIS HELPS
racingant
Apr 13, 2004 11:58 PM
Dspad_91Civic
Mar 17, 2004 03:43 PM
