WTB : Turbonetic Silicone Hose for B16 stock throttle body to charge pipe. (18G GReddy turbo kit)
Old Oct 20, 2003 | 09:03 PM
turboedsi's Avatar
Default WTB : Turbonetic Silicone Hose for B16 stock throttle body to charge pipe. (18G GReddy turbo kit)
Looking for turbonetic Silicone hose that goes from throttle body to charge pipe on a b16 motor. I have the GReddy 18G turbo kit.
I would do the searching myself and get a brand new one. but i cant find any part numbers and "turbonetic" brand hoses. any help would be great, also if your sellin a " brand new" hose, please PM me or email me at civicsi00blue@***.net
Thanks for look.
andy
Old Oct 26, 2003 | 09:15 PM
turboedsi's Avatar
Default Re: WTB : Turbonetic Silicone Hose for B16 stock throttle body to charge pipe. (turboedsi)
BUMP. someone most know.
Old Oct 26, 2003 | 09:53 PM
99blackcivicSi's Avatar
http://www.greddy.com/products...e.htm
Scroll down half page they have the part #'s for the reducers there
Old Oct 27, 2003 | 09:39 AM
turboedsi's Avatar
Default Re: WTB : Turbonetic Silicone Hose for B16 stock throttle body to charge pipe. (99blackcivicSi)
Thanks, but as the post says im looking for " turbonetic silicone hose". he he
Old Oct 27, 2003 | 10:10 AM
Just curious why do you need a turbonetics hose? they are all the same its just that some are more expensive than others due to having names on them IE: turbonetics.
Old Oct 27, 2003 | 10:51 AM
turboedsi's Avatar
Turbonetic hoses are made a lot better than the GReddy ones. Im having a problem when im boot 15psi, my pipblows off and using a better prodct such as Turbnetic will help me out, reason being is they use stronger materials in therehoses compard to GReddy. End result, no more pipe flying off.
later, andy
Old Oct 27, 2003 | 01:56 PM
Mine hasn't blown off at 15 psi yet
Not to sound like an *** but are you installing them correctly.
Old Oct 27, 2003 | 08:30 PM
turboedsi's Avatar
yes i am
Old Oct 27, 2003 | 10:21 PM
Deluzional's Avatar
I was never too picky of the silicone hose brand, I bought mine off ebay and that works great. BTW what kind of clamps are you using?
Old Oct 27, 2003 | 10:28 PM
Top Ramen's Avatar
Default Re: WTB : Turbonetic Silicone Hose for B16 stock throttle body to charge pipe. (Deluzional)
If it is not damaged, the problem is probably not the hose. Just weld a small bead around the end of the pipe so the clamp has someting to prevent it from sliding off. I do that for every setup I build.
Good luck.
Old Oct 31, 2003 | 09:42 AM
turboedsi's Avatar
Default Re: WTB : Turbonetic Silicone Hose for B16 stock throttle body to charge pipe. (Top Ramen)
everything is installed correctly, im using the stock/normal clamps that came with the kit. My hose is starting to dry rott a lil bit. So i think im gunna buy a new greddy one and use " T" clamps ( i think thats what there called) and see how that does. I hear that the "T" clamps ( if thats what there called) work a lot better than the normal radiator clamps that came with the kit.
Off of the subject, if i tune to 15psi, do i need a 3 bar map sensor? Right now im at 12psi and get code 45 sometime ( to rich to lean).
Thanks, andy
B18CUL8R
Sep 19, 2015 12:41 PM
ktran1
Jul 19, 2004 06:26 AM
turboedsi
Sep 2, 2003 09:29 PM
igo4bmx
Apr 26, 2003 08:41 PM
TEG2001
Aug 31, 2002 12:12 AM
