ok some sound after i release gas from turbo??
Old Oct 20, 2003 | 08:21 PM
2000vsm's Avatar
Default ok some sound after i release gas from turbo??
ok i got bov so the pressure goes away, the spring is NOT tight because at idle it's opened a bit..... so anyway,, once i let off on the gas, there is this sound like scratching noise, like once or twice, kinda like turbo winding down???? i dunno because if i boost then just clutch in, there's no sound, but if i boost then let of gas and decel, the sound is there.... wtf is this???
Old Oct 20, 2003 | 09:28 PM
racinskittle's Avatar
Default Re: ok some sound after i release gas from turbo?? (2000vsm)
I actually have something that's sorta similar to that too. It's a ******* WIERD NOISE.
I let off the gas and it sounds like the hinges of a door are squeaking closed. im thinking it's the rusty wastegate actuator arm that's closing, but it just doesn't seem like it. Maybe i have the compressor side clocked too tighly and the wastegate arm is rubbing against the actuator.
Check the videos of my car. Any of the noises sounds familiar? I think i know what ur talking about
http://www.uwm.edu/~mdwarren/D...r.mov
Anyways, i think mine might make the same noise as your describing. Does it?
Old Oct 21, 2003 | 08:33 PM
2000vsm's Avatar
Default Re: ok some sound after i release gas from turbo?? (racinskittle)
??? i can't really hear it, can you tell me where in the vidoe?
N4m
Aug 8, 2012 12:53 PM
skynyrd006
Apr 30, 2006 05:46 PM
SlowB16si
Aug 26, 2005 08:38 PM
SinSeven
Apr 16, 2003 11:09 AM
