What cams?
What cams are you guys making the most power with? I am putting a b18cr into my crx, and all I really want other than the motor is some nice cams to go along with the already awsome motor. I was thinking jun 3's. Any other suggestions. Or just keep them stock and be happy?
depends on what you want to do with your motor. for a nice, reliable motor that still makes great power, raise the compression and either keep the cams stock or throw some toda spec A's in there.
i always liked that combo, with a good header and tuning.
depends. There are lots of different combos to go with. I know of someone making over 200whp on JUN3s with minor tuning, with the cams 0,0 and stock exhaust. it just depends and there is a lot to choose from. you can make some really nice power on the stock cams so you might want to look into that.
your CR has a lot to do with it . Some cams like the Spec D by toda need a lot of high CR to get the best out of them .
Skunk stage 2 are nice for low CR like 11.1 to 11.5 also the Toda A are nice with that same set up.
Jun stage 3 make some nice power also how high do you plan on reving the motor ??
null.
Jan 23, 2007 10:17 AM
B18Redline
Jan 2, 2005 08:22 PM
