-help wiring a apexi v-afc-
i have an apexi v-afc and was wondering if anyone can tell me what color wires on the vafc harness to splice into what color wires on the ecu
i have a 92 civic hatch
okay.... i went to the site and got the diagram. but i was wondering if someone could tell me what colors these wires are on the ECU :
IG POWER
GROUND
RPM SIGNAL
THROTTLE SIGNAL
VTM SIGNAL
VTEC SOLENOID
PRESSURE SWITCH
and also on the diagram it shows where the rest of the wires go from the vafc to the ecu but i was wondering if u need to hook them up closer to the ecu. also what do they have those X's for ...thanks
IG POWER
GROUND
RPM SIGNAL
THROTTLE SIGNAL
VTM SIGNAL
VTEC SOLENOID
PRESSURE SWITCH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxHATCHATTACK »</TD></TR><TR><TD CLASS="quote">okay.... i went to the site and got the diagram. but i was wondering if someone could tell me what colors these wires are on the ECU :
IG POWER
GROUND
RPM SIGNAL
THROTTLE SIGNAL
VTM SIGNAL
VTEC SOLENOID
PRESSURE SWITCH
If you have the correct diagram, it will show you where each of those wires is located on the ECU harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxHATCHATTACK »</TD></TR><TR><TD CLASS="quote">and also on the diagram it shows where the rest of the wires go from the vafc to the ecu but i was wondering if u need to hook them up closer to the ecu. also what do they have those X's for ...thanks </TD></TR></TABLE>
All of the wires get spliced into the the ECU harness.
IG POWER
GROUND
RPM SIGNAL
THROTTLE SIGNAL
VTM SIGNAL
VTEC SOLENOID
PRESSURE SWITCH
i went to the apexi website and got the pdf file with the whole installation and everything...it tells you what to wire the vafc wires to on the ecu but it doesnt say what pin or color the wires are ...that is my question
Download this V-AFC Update. It contains the pin-out locations of all the necessary wires.
Neo218
Aug 3, 2009 06:13 PM
tyflip2
Dec 3, 2003 05:53 PM
