update of my crx racecar
i got it bead blasted and primered, it deformed my doors, is there anyway to get the waves out of my doors or do i need to get new ones or fiberglass.. i can probably get some better pics tomorrow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 »</TD></TR><TR><TD CLASS="quote">Do i see a chiuahuah (sp) in your engine bay
haha, its my old rear motor/tranny mount
</TD></TR></TABLE>haha, its my old rear motor/tranny mount
very nice, I'm sure you'll have no problem meeting minimum weights, prolly may hav eot ballast some, old paint weighs a ton, and you jsut took all that off ? thats great.
Are you throwing a b-series in there or other ?
Greg
Greg
i hope i get all of your questions..
im using a MB 2ng gen crx front end, its gonna have a k-series (k24 destroked to 2.3 with k20a head), the old paint was totally bead blasted off and there was just a little bit of rust under the windshield cowl on each corner.. i was suprised there wasnt more!
heres a small update..
thats my tenzo ARRRR seat, it was cheap and should get the job done.... i didnt get a pic, but i took the doors off, im waiting for the fiberglass ones to get here.. and i spent about 4 hours trying to do the ******* lexan... but it wouldnt cut right.. it would just splinter and crack. So i need to go to home depot again and get the right stuff hopefully this time, i think the stuff i have is way too thin, and might be the wrong stuff..
unless your home depot is different from ours your gettin the wrong stuff. nhra requires a 1/8" thick lexan. a good place to look for it is at a window store or like a mom and pop type home improvement center.
ya.. the homedepot here has 3/32" which i got
through like 1/2" or something... its the right stuff.. but i just got it too thin..
what do you guys use to cut it?
through like 1/2" or something... its the right stuff.. but i just got it too thin..what do you guys use to cut it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy »</TD></TR><TR><TD CLASS="quote">
what do you guys use to cut it?</TD></TR></TABLE>
i carefully used a jig saw.
cutting lexan works best with a router,using a flush cut bit u can make a template of ur glass with 3/4 mdf and use it as ur jig that way ur cuts are perfect and won't crack or look like a pissed of beaver cut it out for u
rotozip and a steady hand...
Another thing to help is to put a piece of 1/4" board underneath the lexan, and it will help to balance and hold the lexan leve so it won't be as flexed.
Why not just buy them pre done???? http://www.optauto.com/webstor...t=854
Options probably has them in stock..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NFJohn »</TD></TR><TR><TD CLASS="quote">Why not just buy them pre done???? ..</TD></TR></TABLE>
Cause its about 1/4th of the price. and besides, cutting , fitting and riveting lexan is fun
nice work
