My #2 cylinder is running richer than others?
Old Oct 20, 2003 | 05:58 PM
Turbocivic94's Avatar
Default My #2 cylinder is running richer than others?
Every other cylinder is running fine but #2 cylinder is running way too rich. I dont understand why? any suggestions
Old Oct 20, 2003 | 06:00 PM
evoeone's Avatar
Default Re: My #2 cylinder is running richer than others? (25 PSI CRX)
how do you know this? do you have a o2 for that runners... or have et's for everyr cylindr..... just curious
Old Oct 20, 2003 | 06:02 PM
littlebluecrx's Avatar
check your compression, do a leak down, if all is fine I would swap injectors and see if it follows the injector, could have a leaky one.... Jason
Old Oct 20, 2003 | 06:56 PM
madman604's Avatar
Default Re: My #2 cylinder is running richer than others? (evoeone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evoeone &raquo;</TD></TR><TR><TD CLASS="quote">how do you know this? do you have a o2 for that runners... or have et's for everyr cylindr..... just curious</TD></TR></TABLE>
dirty plug maybe? but maybe its just poor burn in that cylinder or weak spark. try new spark cables
Old Oct 20, 2003 | 08:40 PM
Tinker219's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 25 PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">Every other cylinder is running fine but #2 cylinder is running way too rich. I dont understand why? any suggestions</TD></TR></TABLE>
I noticed that...lol. He returned the manifold because of creep problems, so its getting replaced w/an SST in the next couple weeks. #2 is still golden, while the rest are purple. check your injectors. Swap them around, see if the colors change runners on the next mani
Old Oct 20, 2003 | 09:19 PM
racinskittle's Avatar
Default Re: My #2 cylinder is running richer than others? (Tinker219)
I would definately make sure there's a decent spark. Check plugs and wires for sure.
After pulling my plugs b4 doing a compression test, that was actually my worst fear lol. What the hell do i do when all of them are clean except for one which is pitch black was what i was thinkin
I really curious what'd cause this too, so im interested to find out.
How's the car running?
Old Oct 21, 2003 | 07:31 PM
ya I was going to do that when I get the mani back, if the injector is leaking what do I have to do?
Old Oct 21, 2003 | 07:32 PM
#2 plug is black
Old Oct 21, 2003 | 07:35 PM
XSIintegra's Avatar
check the wires and plugs as suggested. After that, most likely that injector. Had one do just the opposite on my old LS w/ nitrous and that cyl popped, because of a bad injector (leaned out).
Old Oct 22, 2003 | 05:50 AM
Tinker219's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 25 PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">#2 plug is black </TD></TR></TABLE>
you have a wb02? if so, what was it running? injector might have stuck open...
Old Oct 22, 2003 | 07:01 AM
I got wb02 and regular, my wb is @ 11:8:1
Old Oct 22, 2003 | 07:02 AM
Tinker219's Avatar
interesting....im assuming compression is good? Vadian had bad compression, and his #4 cylinder I belive wasnt firing at all. His runner was exactly the same color as it was when it left my house....
Old Oct 22, 2003 | 07:09 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
While the car isn't running How about getting the injectors flow tested.
Old Oct 22, 2003 | 08:02 AM
4U2NV's Avatar
Default Re: My #2 cylinder is running richer than others? (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">While the car isn't running How about getting the injectors flow tested.</TD></TR></TABLE>
... Sounds like a siezed injector to me...
Old Oct 22, 2003 | 11:14 AM
compression is 210 across
Old Oct 22, 2003 | 11:15 AM
I had them flow tested before I put them in my car. I guess I'll have them done again.
Old Oct 22, 2003 | 12:29 PM
MachAF's Avatar
Check the wiring on the fuel injectors.
But usually if the wiring is messed up the injector will stick open and you will get misfires.
Old Oct 22, 2003 | 01:25 PM
Default Re: My #2 cylinder is running richer than others? (MachAF)
I had to wire in resistor box, maybe wires r not connected right. I'l check for that.
.BigSexy
May 19, 2007 10:54 AM
92bubblesi
Jun 15, 2004 12:38 AM
project142
Jan 28, 2004 06:06 PM
magic hat #9
Sep 19, 2003 08:23 AM
Evil EG
May 25, 2003 11:29 PM
