Guys with high horsepower ... fuel delivery question
You guys with 500-600 whp / stock fuel tank. Do you have problems of fuel pump sucking air when you launch real hard with only about 1 galon of race fuel left in the tank ?
When i launch its fine, when i get on the brakes, it gets a lil air, but i like to keep a fair amount of gas in the tank to avoid that..
my question is more oriented towards in-tank users , unless the strainer is exactly at the same place with an inline pump. Inform me.
I have stock tank with sump in it with aeromotive external pump, filter, and full fuel lines, ect. My car is driven on the street, and if i have less than 1/2 tank of gas when slamming on the gas or taking a turn hard air gets in the lines, and i stall. I have to keep turning it over until the fuel pressure goes back up than it will start back up.
I run an intank Walbro and I keep it at about 1/4 - 1/2 tank, never have had a problem. You should try and not run your car with that little gas. Brian
sorry for being kinda off topic but
hybrid901> when you drive in the streets, do you watch your exhaust temp?
if yeah, like around 4k in freeways, do you notice that it get's really lean?
and what fuel setup are you using?
my friend's civic who dyno'd 421hp 3xx tq, keep on having problems who also blew his motor and ran 3 cylinders back from soCAL and norCAL!
he has a bbk intake pump, stock fuel lines. It was tuned by a really good tuner (hondata), but he kept on having problems.
you can PM/email me if you want.
i use a inline pump with a stock tank and never have problems at any gas level.i drive it on the street from full to well past when the light comes on and never have had a problem.at the track,i usually run 4-5 gallons of 118.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 »</TD></TR><TR><TD CLASS="quote">Good thread.
What is the most power someone has made w/ out a sump and external fuel pump?</TD></TR></TABLE>
It has to be littlebluecrx with his 255lph intank that ran 9s,someone correct me if im wrong.
BTW...Dont run it with only one gallon in the tank,please put alittle more in,thats barely enuff to fill the reserve pan inside the tank...I say use one gallon if you plan to blow it up by leaning it out when it starves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man »</TD></TR><TR><TD CLASS="quote">
No, he said the most HP.
I'm at 510 whp on a Mustang Dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinxproof99 »</TD></TR><TR><TD CLASS="quote">i always kept 5 gallons in the car. i suggest you do the same.
Sounds like an expensive proposition to me, cause when I leave the track I lower the boost and fill up with 94 octane. The car's my daily commuter, and I don't want to waste 2-3 galons of my 20-bucks-a-gallon c16
</TD></TR></TABLE>Sounds like an expensive proposition to me, cause when I leave the track I lower the boost and fill up with 94 octane. The car's my daily commuter, and I don't want to waste 2-3 galons of my 20-bucks-a-gallon c16
First of all hi guy's great site for Honda hardcore ,its Meanteg who introduce me here .so far i am not disapointed of what i read .
For the main question , i had the choice to call Meanteg on the phone or to answer here . i decide to answer here as my first post and to gave some ( maybe ) good info .
i did not Drag race a lot with my teg , anyway it only does 14 low on the 1320 . I do more Solo 1 with it , i built it in that purpose i like hard cornering
. when i do solo 1 i cant race with my fuel under 1/4 level , when it get under 1/4 and i take tight curve and high G's . My car start stalling because the strainer grab some air .
on a 10's car the condition when accelareting may be the same as me taking a high G's curve . So he should keep at least half a tank to prevent that problem
Modified by Mart at 4:12 PM 10/22/2003
. when i do solo 1 i cant race with my fuel under 1/4 level , when it get under 1/4 and i take tight curve and high G's . My car start stalling because the strainer grab some air . on a 10's car the condition when accelareting may be the same as me taking a high G's curve . So he should keep at least half a tank to prevent that problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinxproof99 »</TD></TR><TR><TD CLASS="quote">so i guess you don't like doing burnouts in third on the highway @ like 75 mph......hahaha. try it, you'll like it.
haha I did !! 17 psi w/ 94 octane is enough to smoke the RA1's at 70 mph ..
</TD></TR></TABLE>haha I did !! 17 psi w/ 94 octane is enough to smoke the RA1's at 70 mph ..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanteg »</TD></TR><TR><TD CLASS="quote">
Its true i saw the whole thing , right next to my passenger door
</TD></TR></TABLE>Its true i saw the whole thing , right next to my passenger door
Smarter than you
I'm at 510 whp on a Mustang Dyno. </TD></TR></TABLE>
what fuel pump are u running? Hybrid901 made 530whp dynojet on a walbro intank that was the highest i knew of before i asked the question.
what fuel pump are u running? Hybrid901 made 530whp dynojet on a walbro intank that was the highest i knew of before i asked the question. </TD></TR></TABLE>
walbro 255 hp
stock fpr
walbro 255 hp
stock fpr
we are running a mostly stock fuel system in the hatch im working on. just s walbro 255high pressure, B&M regulator and aem fuel rail. all the lines/tank are all stock. it made 510 last weekend with a few bug that need to be worked out.. should be another 80hp left in it.. at least
Modified by JDogg at 11:12 PM 10/22/2003
