Ignition switch replacement
Old Oct 20, 2003 | 05:06 PM
Fkned's Avatar
Default Ignition switch replacement
hey anybody else have to replace the switch?WTF cars only 10 yrs old and wont move.MFing imports my 701/2 camaro is 33yrs old and no problem,never had a key related problem with any cars owned and I've owned some shitty cars in my day. Is this common with hondas.BTW 93 del sol
Old Oct 20, 2003 | 05:21 PM
aw1234dude's Avatar
Default Re: Ignition switch replacement (fkned)
I've replaced mine before after a thief broke the ignition switch off. I bought the switch at the dealer for about 100 bucks. The hardest part when installing the switch is the removal of the old one. The switch is clamped around the steering column with two break-a-way bolts. There is no way to remove the bolts with a screw driver or anything because there is no kind of real head to it. So what I did was I took my dremel rotary tool and used a cut off blade to cut through each bolt. There was just enough room to get in between the two clamps. If you have a really small circular cutting tool I suppose you can cut slits in the break-a-way bolt heads but I wasnt able to squeeze my dremel in there. Good Luck...
Old Oct 20, 2003 | 06:36 PM
Fkned's Avatar
Default Re: Ignition switch replacement (aw1234dude)
I already fixed it BWTF it cost me $300 at the dearler *************.Yeah I used a cut off whell too ,but I cut the clamping band instead of the bolts.
Old Oct 20, 2003 | 07:27 PM
solo2slocivic's Avatar
if the lock isnt broke or damaged just replace the electrical portion of the switch..... alot cheaper than a $300 lock assy.
Old Oct 20, 2003 | 07:35 PM
Fkned's Avatar
Default Re: (solo2slocivic)
No the key wouldn't turn,already put in anyway,just bitch in about it.
Old Oct 20, 2003 | 07:43 PM
cxSHOE's Avatar
Default Re: (fkned)
3bills?? damn, what so special about the del sol ignition, should have only cost you about $110. or did they install it for you???
and the junkyards have them for about $50-75 bucks. with keys then just buy universal knock off bolts at home depot...
i agree i had a 68 dodge charger,, orginal key, never a problem... oh well..
fin781
Apr 23, 2011 01:13 PM
Stiff_Crx
Oct 28, 2009 03:55 PM
jaghouse
Jun 15, 2007 12:28 PM
urbanlegend21
Dec 21, 2005 07:15 AM
davew
Aug 28, 2001 05:57 AM
