04 parts with 00-03?
I know the 04s just came out but have any of you seen 04 parts swapped on to 00-03 models, for example like the head lights or rear lights? or somthing like a 04 wing or lip on a 00-03?
http://forums.s2ki.com/forums/...57765
http://forums.s2ki.com/forums/...58288
With the 04 front bumper the 03 lights fit so I'm sure it's the same vice versa.
04 rear lights should fit as well.
04 wing will fit.
04 lip on 03 bumper? Has yet to be determined.
04 wing will fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMS JT »</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
I stand corrected. According to JDMS2000 on S2ki:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMS2000 »</TD></TR><TR><TD CLASS="quote">Just got back from the dealer. The 04 taillights are not a direct bolt in. Like I said before you will need the 04 trunk harness plus you will have to do some cutting to make them fit properly. Upon inspection of the 04 taillamps it seems they use 3 bolts which are different than the 00-03 setup. Plus there are 3 holes in the back of the lamp vs. 2 that the 00-03 have. So you will have to do some custom fab and cut and adjust the hole size in the back. Even the existing holes in the 00-03 are not the right size or shape as the 04s. So not really worth it IMO to switch over. I cancelled my order and ordered the 03 taillights. If anyone is wondering they are not that expensive. I believe they are $180 a piece so around $360 for the 04 tails. Funny thing is the 03s are 5 dollars more per side. Go figure. LOL</TD></TR></TABLE>
.</TD></TR></TABLE>
also the tails have LED's. which have a ballast which needs more space to be banged out of the inside of the tail housing of the car. headlights, bolt in, just need to do some remounting of the HID ballast. front bumper is direct bolt up, except you have to take MY00-MY03 foam out of the re-bar. rear bumper bolts up from what ive seen on that one.
