Is this noise from brake pad indicator? vid
Old Oct 20, 2003 | 11:40 AM
Dracord's Avatar
Default Is this noise from brake pad indicator? vid
Annoying squeek when turning right. Doesn't happen when stopping though. Any other ideas?
http://www.dracord.com/squeek.mpg
4mb
Old Oct 20, 2003 | 12:48 PM
eL's Avatar
eL
<------- Stumped. That doesn't sound like the brakes at all to me. Hint: its when you turn... i highly doubt its the brakes. goodluck.
Old Oct 20, 2003 | 12:49 PM
briq4's Avatar
Default Re: Is this noise from brake pad indicator? vid (Dracord)
Most likely yes, easy to check the brakes tho, just pull the wheel, loosen the bottom caliper bolt, swing the caliper up and look at the pads, if it is the wear indicator you will see it's "shiny" where it would contact the rotor, brakes are an EASY fix.
Old Oct 21, 2003 | 05:42 AM
accord91lx's Avatar
Default Re: Is this noise from brake pad indicator? vid (briq4)
yea my wear indicators at first were only audible when i was turning... then eventually it started randomly squeeking.... then it started the constant squeel... was embarrasing going through town with the squeek squeek squeek..........and 99% of the time i wasnt even touching the brake peddle..
Old Oct 24, 2003 | 06:49 AM
. C h e n l a's Avatar
Default Re: Is this noise from brake pad indicator? vid (desolate)
you could have a leak in ur wheel bearings, i got mine fixed and all my weird sounds left.. after i got my grinding brake pads fixed...
Old Oct 25, 2003 | 11:16 AM
sauceman's Avatar
Default Re: Is this noise from brake pad indicator? vid (Chenla24)
That's not your wheel bearing, it's your lower ball joint going dry. Try re-lubing it, and if it re-appears after a few days, you're gonna have to change it.
Oknoe.
Apr 21, 2010 04:10 PM
HondaAccordTdR
Honda Motorcycles
10
Sep 6, 2007 03:43 PM
potatostix
Oct 26, 2005 05:54 AM
highwayman
Aug 8, 2005 07:12 AM
Lazydsm
Dec 9, 2003 08:35 PM
