Y3 - how to tell if it is a Dx or Si trans from outside???
Old Oct 20, 2003 | 08:35 AM
AgentJam's Avatar
Default L3 - how to tell if it is a Dx or Si trans from outside???
It's hooked up to my Y8 so i can't look at the internals but is there any indication on the outside? or code on the trans somewhere?
Correction L3 trans...not Y3
Thanks,
VINCE
Modified by AgentJam at 6:47 PM 10/20/2003
Old Oct 20, 2003 | 12:18 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: L3 - how to tell if it is a Dx or Si trans from outside??? (AgentJam)
look near the tranny filler hole...........
PL3-A000 = small bearing case, usually DX
PL3-B000/6000/9000 = large bearing case, only Si/EX
Old Oct 21, 2003 | 06:52 PM
revhigh89's Avatar
Default Re: L3 - how to tell if it is a Dx or Si trans from outside??? (Mista Bone)
thanks for the info! ure the greatest buddy!
Old Oct 22, 2003 | 12:09 AM
Nerologic's Avatar
not to doubt the D series master but i recall reading a thread that there was no actual 100% bulletproof way to figure out what tranny it is just by the casing marks cuz there were exceptions for like every tranny...?
Old Oct 22, 2003 | 05:52 AM
redzcstandardhatch's Avatar
something different
Default Re: (Nerologic)
mista bone is right, both my si trannies said the same thing, and i had a dx that was just as he described it. also, if its in the car, you'll be doing about 4000 rpm's at 80 or so with the si
Old Oct 22, 2003 | 06:17 AM
AgentJam's Avatar
Default Re: (redzcstandardhatch)
So Mista Bone is the D series guru? I have another question for him then...A D16Y8 was just swapped into my car but i think that the drivers side mount is wrong. It looks like it's bent or something, anyway someone told me that i had to switch that mount back to the 4g Crx mounting plate and mount to fit my 88 CRX right. Is this true?
Thanks!
VINCE
Old Oct 22, 2003 | 06:23 AM
slywfbpsi's Avatar
Default Re: (AgentJam)
that would be true, all d15 and d16 motors, bolt in the 88-91 civic.
Old Oct 22, 2003 | 06:25 AM
AgentJam's Avatar
Default Re: (slywfbpsi)
Cool, so the other 3 mounts should be from the Y8 engine and only the drivers side mount should be the original one from my CRX? just making sure
Old Oct 28, 2003 | 09:59 AM
westcoastcat's Avatar
bump,, not all tranny's 92-95 his hydro 88-91 is cable , 96-00 not sure only deal with honda's from 88-95
Old Oct 29, 2003 | 04:27 AM
slywfbpsi's Avatar
Default Re: (blcwsfly20)
I said nothing about trannies . I said all d15 and d16 motors fit in the 88-91 civic.
BlueRex1020
May 26, 2007 01:22 AM
CrxSi707
May 25, 2004 08:56 AM
H.crx-si
Jan 10, 2004 09:42 AM
Wes d
18
Jun 6, 2003 08:53 PM
Nerologic
12
May 21, 2003 11:08 PM
