AutoX HS questions
Old Oct 20, 2003 | 07:29 AM
p0pe's Avatar
Default AutoX HS questions
I'm about to start AutoX'ing and I have a couple of questions for the accords here running in HS.
1) Your only allowed stock wheel size, which is 15x5.5 right (97 ex alloys)? And how big of a tire do you run? I'm guessing 205/50/15 or 205/55/15..
2) Bigger rear sway bars - are they allowed in the stock class?
3) Would a racing flywheel & kevlar face clutch bump me up into SM or SM2?
Modified by p0pe at 11:02 AM 10/20/2003
Old Oct 20, 2003 | 08:06 AM
CD8's Avatar
CD8
Default Re: AutoX HS questions (p0pe)
stock wheels are 15x5.5
they squeeze on azenis all the time.
the rules read "Limited-slip differential, transmission and differential ratios, clutch mechanisms, and carburetion, fuel injection or supercharger induction systems must be standard as herein defined. "
so no you cannot run an aftermarket clutch.
there is nothing stated about the bigger sway bars, although it pretty much says suspension must reamain standard.
also, if the rules dont say it specifically, then you CAN NOT do it.
Old Oct 20, 2003 | 08:44 AM
p0pe's Avatar
Default Re: AutoX HS questions (CD8)
Thanks. Looks like I'll have to run in STS then..
AlphaKennyWun
May 20, 2008 10:42 AM
whole9
11
May 12, 2006 09:10 AM
TypeR1558
Jan 1, 2003 01:19 PM
Knestis
Aug 26, 2002 05:46 AM
hooptie157
May 19, 2002 07:41 PM
