95 honda civic 2dr cp left driver side door(glass)
Hey guys, sorry to bother you, but we got problems. My left drivers side door of my honda civic was broken into, so the glass was everywhere, cleaned it up a bit, but im gonna have to get some new glass installed. Fortunately, i already have glass(extra door(same side) that was taken out because it got hit). Its kinda cold and i have class in about 2hr, can anyone help me knock this out possible before class? Is this gonna be something we can do, or will i need to take this to the dealers?
take the door panel off.... un bolt all the brakets that hold the window in.... vaccumm all the glass out... Place new window in.... re bolt... viola easy
sorry im new and sorry to bother you, but how many brackets do i need to take off...looks like just 2. i took the plastic part of the door of, but im left with a metal frame of some sort and the glass is in between, how do i get the glass out of the door?
thanks civic racer, i just took out the glass there were 2 brackets, that were pretty hard to get at cause since the extra door was disconnected i couldn't use the power to get easier access to the brackets, hopefully we can get this glass in the new door just as easy...ill let you know what happens. thanks, by the way, what do you have done to your car? is it a 95, 2dr cp?
successful...Thanks so much civic racer! now the places i called said that would take about 1 hr. if i knew exactly what i was doing from the start, i couldve nailed it in like 20min, prob less. But now, thanks to civicracer and some trial/error, we're all set! Thanks alot... i wont forget that name-Civicracer!
i noticed how you said "doing b20 ctually B22 T with Semi Rev hard kit with a T3 T4 Built the **** of the bottom end IOda Baxton sleeves - $3400 JDM ***** Lookin to get 18 - 23 psi out of it to make around 350ish...
I have been building motors for a long time buddy, I know what im doing just had a LS Vtec roll over 56K miles on build 2 years ago... and the kid beats the **** out of it every day. So I got it down. I have a B18B1 made to a 2.1 with 14:1 comp that destroys b16 turbos" on FSS | Forum, yet you can't figure out to fix a window?
:thinks BS:
:thinks BS:
STFU asshat
wow another post loser... come on down to FL and I can show you better then I can tell you...
Modified by civiksiracer1 at 11:35 PM 10/20/2003
shut the **** up newb. youre car is rice. go ****** **** off.
my post is just stating the facts. so either A) youre lying or B) youre a retard except when it comes to motors
newb?? I have been a HT member for 3 years with over 2K posts... So **** off you **** knocking newb! your the ****** newb NEWB!
Modified by civiksiracer1 at 11:28 PM 10/20/2003
Kevin420
Honda Civic (2006 - 2015)
Apr 24, 2017 10:31 AM
sypherz28
Oct 2, 2007 03:03 PM
