What is up? - tires sizes and speedometer inaccurate.....
Old Oct 20, 2003 | 06:39 AM
93CivicSI's Avatar
Default What is up? - tires sizes and speedometer inaccurate.....
Got a speeding ticket (77 / 65)- told the officer that I had my cruise set at 74 - he told me to have my speedometer calibrated - go to a shop that he recommended - with my existing tires (195/50-15) on 15 x 6.5 inch alloys - speedometer reads incorrectly - 75 indicated was actually 78...
With my winter tires 195/55-15 on 15 x 6.5 steelies it was dead accurate....
If I plus1 the stock configuration for the 93 Hatch (185/60/14 original) I come up with 195/50-15 - same rolling diameter between the two - what gives?????
Old Oct 20, 2003 | 07:56 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: What is up? - tires sizes and speedometer inaccurate..... (93CivicSI)
what motor do you have?
Old Oct 20, 2003 | 08:01 AM
96 SOHC VTEC's Avatar
Default Re: What is up? - tires sizes and speedometer inaccurate..... (rodney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney &raquo;</TD></TR><TR><TD CLASS="quote">what motor do you have?</TD></TR></TABLE>
Does that make a difference?
Old Oct 20, 2003 | 08:10 AM
Rodney's Avatar
Default Re: What is up? - tires sizes and speedometer inaccurate..... (96 SOHC VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 SOHC VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Does that make a difference?</TD></TR></TABLE>
yes.
Old Oct 20, 2003 | 08:19 AM
Navid OG's Avatar
1st of all motor does not make a difference (not in this case)
if ur using the wrong profile ur speedometer will be inaccurate...... i also learned that the hard way.
Old Oct 20, 2003 | 08:26 AM
Rodney's Avatar
Default Re: What is up? - tires sizes and speedometer inaccurate..... (Navid OG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Navid OG &raquo;</TD></TR><TR><TD CLASS="quote">1st of all motor does not make a difference (not in this case).</TD></TR></TABLE>
YES it does make a difference. if he is using a motor, or should i say an engine swap, that would dictate what tire size would have an accurate speedo.
Old Oct 20, 2003 | 08:31 AM
Padawan's Avatar
Darth ModerVader
You're correct with the 195/50-15's (assuming that the car's original size was 185/60-14). The 195/55-15's are the ones that should be giving you the problem, and they would/should indeed give you and indicated 75 MPH on the speedometer when you are actually traveling 78. Try measuring the actual diameters of the stock and aftermarket setups, to see if perhaps the sizing runs large on your particular tires.
Old Oct 20, 2003 | 08:34 AM
Rodney's Avatar
Default Re: What is up? - tires sizes and speedometer inaccurate..... (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">You're correct with the 195/50-15's (assuming that the car's original size was 185/60-14). The 195/55-15's are the ones that should be giving you the problem, and they would/should indeed give you and indicated 75 MPH on the speedometer when you are actually traveling 78. Try measuring the actual diameters of the stock and aftermarket setups, to see if perhaps the sizing runs large on your particular tires. </TD></TR></TABLE>
but, does he have a swap?
Old Oct 20, 2003 | 08:44 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney &raquo;</TD></TR><TR><TD CLASS="quote"> but, does he have a swap? </TD></TR></TABLE>
Even if the larger 195/55-15's were the correct size for that particular application (i.e. GS-R, ITR), running 195/50's should result in the speedometer reading higher than the actual speed, not lower. I'm not sure how many applications would call for a tire that was smaller than a 185/60-14 (CX/VX maybe?) That being said, what is happening in his case doesn't appear to make any sense, no matter how one looks at it.
Edit: Mainly because he claims to have no problems with the 195/55-15's, but finds that the 195/50-15's give a higher-than-indicated speed.
Old Oct 20, 2003 | 08:51 AM
Rodney's Avatar
thanks padawan. i just wanted to get accurate info on hardware beforehand.
Old Oct 20, 2003 | 08:55 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney &raquo;</TD></TR><TR><TD CLASS="quote">thanks padawan. i just wanted to get accurate info on hardware beforehand. </TD></TR></TABLE>
No problem. I understand what you're saying, but I'm just extremely confused by the situation. To the original poster, are you 100% sure that the tire sizes you've posted are accurate?
Old Oct 20, 2003 | 09:05 AM
BauleyCivic's Avatar
Risky Business
Why did they give you a 77 in a 65 ticket anyway? Thats ******* gay
Old Oct 20, 2003 | 09:09 AM
lsvtec hatch05's Avatar
Default Re: What is up? - tires sizes and speedometer inaccurate..... (BauleyCivic)
cops are gay like that
Old Oct 20, 2003 | 10:01 AM
sil's Avatar
sil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI &raquo;</TD></TR><TR><TD CLASS="quote">If I plus1 the stock configuration for the 93 Hatch (185/60/14 original) I come up with 195/50-15 - same rolling diameter between the two - what gives?????</TD></TR></TABLE>
hrmmm.. i thought civics with 14" diameter rims had 185/65/14 tires stock? Because if that's the case it's nearly dead on rolling diameter of 195/55/15
Old Oct 20, 2003 | 10:04 AM
Rodney's Avatar
Default Re: What is up? - tires sizes and speedometer inaccurate..... (sil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sil &raquo;</TD></TR><TR><TD CLASS="quote">
hrmmm.. i thought civics with 14" diameter rims had 185/65/14 tires stock? </TD></TR></TABLE>
92-95 si or 93/95 ex coupe ran the 185/60-14 stock. 96-00 civic ex's had 185/65-14's.
Old Oct 20, 2003 | 10:06 AM
shauniewalnuts's Avatar
im runnin 17's with 205/40 how much + OR - do you think my speedo is off, 97 ex coupe
Old Oct 20, 2003 | 10:29 AM
Rodney's Avatar
Default Re: What is up? - tires sizes and speedometer inaccurate..... (shaun311)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaun311 &raquo;</TD></TR><TR><TD CLASS="quote">im runnin 17's with 205/40 how much + OR - do you think my speedo is off, 97 ex coupe</TD></TR></TABLE>
185/65-14= 23.46 OD
205/40-17= 23.45 OD
perfect tire size! there is always some discrepancies between manufacturers and OD, but your speedo should be right on the money
Old Oct 20, 2003 | 10:39 AM
nicccce
Old Oct 20, 2003 | 10:59 AM
93CivicSI's Avatar
Stock D16Z6 - original for 175,000 now..
Old Oct 20, 2003 | 11:01 AM
Outrun's Avatar
Default Re: What is up? - tires sizes and speedometer inaccurate..... (lsvtec hatch05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec hatch05 &raquo;</TD></TR><TR><TD CLASS="quote">cops are gay like that</TD></TR></TABLE>
Stupidest response of the day.
Old Oct 20, 2003 | 11:02 AM
93CivicSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Why did they give you a 77 in a 65 ticket anyway? Thats ******* gay</TD></TR></TABLE>
Southern Virginia State Police will write if you are going 11 or more over - PERIOD... - If you are traveling on Interstate 81 be careful from mile marker 60 to 73 regardless of North or South bound.
stickyricky714
May 2, 2008 01:56 PM
.C h r i s
Sep 20, 2006 08:46 AM
jakeiscool
Feb 19, 2006 11:46 AM
BEEYOND
Dec 4, 2004 12:06 PM
jond
May 12, 2004 06:18 PM
