89-91 rear struts in an 88?
Old Oct 19, 2003 | 10:57 PM
pwr_crx's Avatar
Default 89-91 rear struts in an 88?
has anyone put 89-91 rear struts in an 88, i know the 88 has a forked strut, and imformation would bevery helpful.
Old Oct 19, 2003 | 10:58 PM
Malgerus's Avatar
Default Re: 89-91 rear struts in an 88? (pwr_crx)
You need to swap to 89+ lower control arm (or whatever it's called that the shock bolts to at the bottom).
Old Oct 19, 2003 | 11:24 PM
Caleb V's Avatar
89-91 rear shocks have a fork on the end, the 88's have a bushing that the LCA surrounds on both sides.
Struts are on the front of a 1984-1987 CRX they not only support the weight of the car but also are carrying side loads and thus have a larger diameter shaft to take all the extra abuse compared to a shock that sees most of its forces just straight up and down.
88 LCA bent/rolled sheet steel
89-91 LCA solid cast
Ryan Lantz
Feb 16, 2014 07:25 PM
Skipper75
Suspension & Brakes
Apr 20, 2007 07:54 AM
Skipper75
Apr 16, 2007 06:48 AM
Maxpower350
Mar 26, 2006 12:23 PM
