CRX starts without clutch engaged!?
Old Oct 19, 2003 | 10:55 PM
B2FiNiTY's Avatar
Default CRX starts without clutch engaged!?
My gf started the car without the clutch engaged last night. Totally blew me away. It starts up just fine as if the clutch was in. I did it later that night to confirm that it works and indeed it does. Everything sounds normal and what not.
What could be the cause of this? What harm is being done?
Old Oct 19, 2003 | 10:57 PM
Malgerus's Avatar
Default Re: CRX starts without clutch engaged!? (B2FiNiTY)
Is it an 88?
All 88 Civic/CRX's didn't come with a neutral safety switch. You can always install one though.
Old Oct 19, 2003 | 10:59 PM
quiambao1180's Avatar
if its an 88 then thas how they made em for some reason i had a 88 crx si and a 88 hatchback dx and they both started witout steppin on the clutch aint nothin wrong wit it.........
Old Oct 19, 2003 | 11:00 PM
SIRX's Avatar
Default Re: CRX starts without clutch engaged!? (quiambao1180)
actually most vehicle's 88 and before would start without the clutch pushed in.
Old Oct 19, 2003 | 11:01 PM
Malgerus's Avatar
Default Re: CRX starts without clutch engaged!? (SIRX)
Yup, to switch it over, you'd need the relay and an 89-91 pedal assembly. I'm using an 89 CRX Si one in my 88 hatch (just haven't bothered to wire it yet).
Old Oct 19, 2003 | 11:15 PM
rodrez.'s Avatar
My 93 hatch starts w/out the clutch. I had an autostart installed a few years back, but since disconnected it, still starts w/out the clutch. I like it better that way personally.
Old Oct 19, 2003 | 11:27 PM
B2FiNiTY's Avatar
Default Re: CRX starts without clutch engaged!? (rodrez)
Ahhh! Very special. Yes sir, 88 CRX Si
Old Oct 20, 2003 | 12:23 PM
Mista Bone's Avatar
D Tranny Guru
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">My gf started the car without the clutch engaged last night</TD></TR></TABLE>
Well, when you push the clutch pedal down, the clutch is not engaged.
Called a clutch safety switch.
Sorry to be an a$$hole, but reread your first line.
Old Oct 20, 2003 | 12:41 PM
RiceRacist's Avatar
Default Re: CRX starts without clutch engaged!? (Mista Bone)
I have an 89 Si and I can start my car without pushing in the clutch
Old Oct 20, 2003 | 12:51 PM
Mr Furball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry to be an a$$hole, but reread your first line.</TD></TR></TABLE>
Thats what I was thinking.
Don't worry about it, and if you do want to change it, you do not have to get the whole pedal assembly, all you need is the pressure switch and relay, out of 90 up.
Old Oct 20, 2003 | 12:57 PM
EL Vap133's Avatar
So you didn't know this about your own CRX?
Old Oct 20, 2003 | 01:58 PM
Swift's Avatar
Personally I think the neutral safty switch is a bad idea. Before that darn switch if you ever broke down in the middle of the road then you could just put you car into first and use the starter to drive it over to the shoulder.
Old Oct 20, 2003 | 10:19 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: CRX starts without clutch engaged!? (Swift)
or off the railroad tracks!!!!!!!!!!!
PUSH&gt;&gt;&gt;&gt;&gt;&gt;&gt;&gt;&gt;
Old Mar 21, 2012 | 09:20 AM
jdmboy562's Avatar
Icon4 Re: CRX safty neutral switch loction
i cant find the neutral safty switch on my crx automatic plz txt back with info my car cant shift of from parking its stuck
Old Mar 21, 2012 | 09:22 AM
jdmboy562's Avatar
Icon4 Re: CRX starts without clutch engaged!? (B2FiNiTY)
were can i find that switch ? neutral safty switch??? bro help me out my shift is stuck on parking
journeyquest
Mar 11, 2013 05:04 AM
ryanmh22
Oct 6, 2012 03:43 PM
S A D A N
Mar 17, 2009 06:48 PM
Rob.
18
Apr 14, 2008 02:42 AM
jadugartir
20
Aug 6, 2004 08:43 AM
