cam gear settings for itr cams......did search
Old Oct 19, 2003 | 10:07 PM
TwistedHatch's Avatar
Default cam gear settings for itr cams......did search
just wondering if there is kinda a starting point where to set them, i know a dyno is the only real way to tell, but my other motor is beeing built and will be dyno'd on hondata. right now just running a chipped ecu and tryin to figure out where they make some good power
Old Oct 19, 2003 | 11:12 PM
junya16's Avatar
Default Re: cam gear settings for itr cams......did search (TwistedHatch)
0,0
Old Oct 19, 2003 | 11:35 PM
J2turbo21's Avatar
Default Re: cam gear settings for itr cams......did search (junya16)
A guy i know said something about retarding for tq and advancing int or ex for hp but i think he is totally full of **** Most likely people will say "every motor is different so there is no specific settings".
Old Oct 20, 2003 | 02:20 AM
Default Re: cam gear settings for itr cams......did search (J2turbo21)
that is true, but there has to be some kinda setting........i know that from advacing the intake to +4 made it faster.........i know there are some people running these cams and i dont' care if each motor is diff, where are you running them, like i said, new motor will be done soon, don't want to waste money on dyno
Old Oct 20, 2003 | 08:02 AM
ihaterice's Avatar
get the car on a dyno - only way you will really tell if the adjustments that you are making are making power or losing power - everyone's engine is different so the settings for one engine won't necessarily make power on your engine
james
Old Oct 20, 2003 | 11:30 AM
Default Re: cam gear settings for itr cams......did search (ihaterice)
i'm well aware of that, but the problem is i don't wanna dyno and waste money on this setup, i wanna spend the money on my new motor, i just wanna know what people are running for adjustments, that way i have some to try, instead of just driving everytime i move the gear 1 deg
Old Oct 20, 2003 | 11:59 AM
b19coupe's Avatar
Two motors that I ran ITR cams on both liked the intake at +4. One liked -2 on the exhaust, the other liked the exhaust at 0.
Old Oct 20, 2003 | 12:41 PM
HONDABROMANDUDE's Avatar
Default Re: cam gear settings for itr cams......did search (b19coupe)
While I was hanging out at a VERY reputable shop in socal I heard the tuner say that the smaller cams like itr, ctr and skunk2 stage 1's almost always did best at +4 for the intake and -1 for the exhaust.
Old Oct 20, 2003 | 07:09 PM
ihaterice's Avatar
Default Re: cam gear settings for itr cams......did search (itec311)
is this +4, -1 etc of actual crankshaft rotation or on the cam gear degree markings?
Old Oct 20, 2003 | 11:03 PM
junya16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ihaterice &raquo;</TD></TR><TR><TD CLASS="quote">is this +4, -1 etc of actual crankshaft rotation or on the cam gear degree markings?</TD></TR></TABLE>
i'm guessin cam gear degree markings
Old Oct 21, 2003 | 10:14 AM
itr8's Avatar
Yes, cam degree markings.
Old Oct 21, 2003 | 10:49 AM
-KangaRod-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">A guy i know said something about retarding for tq and advancing int or ex for hp but i think he is totally full of **** </TD></TR></TABLE>
definitely full of ****, I've never seen any mods that add hp. Only low rpm torque or high rpm torque.
+4 intake, and -2 exhaust is what I've heard is a good starting point.
Old Oct 27, 2003 | 11:08 PM
Mikeman191's Avatar
Default Re: cam gear settings for itr cams......did search (-KangaRod-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- &raquo;</TD></TR><TR><TD CLASS="quote">
Thank you x100 for not posting about how "every motor is different..." all people are looking for is a starting point to tuning their cams.. i know im not going to drop 150 at the dyno to pick up 2 HP.. Thanks for the useful info!
Old Oct 28, 2003 | 07:13 PM
Mikeman191's Avatar
hp is derived from torque... cant have one without the other... definately full of ****..
Old Jun 21, 2004 | 04:54 PM
jt-sport's Avatar
Default Re: cam gear settings for itr cams......did search (itr8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr8 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, cam degree markings.</TD></TR></TABLE>
itr8 are you sure? you heard it or you set it.?? it mean +8degree in crankshaft..
Im not tryin to be a wise *** , im just one that also want to learn
I want to hear b19coupe answer this ....
Old Jun 21, 2004 | 09:55 PM
biassj's Avatar
Default Re: cam gear settings for itr cams......did search (jt-sport)
Man, can't you hit your intakes valves with that much advancement?
Old Jun 21, 2004 | 10:05 PM
asubennett's Avatar
Default Re: cam gear settings for itr cams......did search (biassj)
Stock long block the answer would be NO.
Old Sep 4, 2004 | 01:06 PM
buffgsr's Avatar
what about skunk2 stage2 cams heard of any good starting points there
Old Sep 8, 2004 | 01:56 PM
FrankBullitt's Avatar
Default Re: cam gear settings for itr cams......did search (buffgsr)
bump for skunk2 stage 2 settings... poll...please thanx.
athoughts
Jan 21, 2005 02:32 PM
gsrx
Dec 15, 2004 10:42 PM
VtecKiDD
22
Nov 3, 2004 10:12 AM
fattymatty
Aug 21, 2004 06:37 PM
bottlefedb18c1
May 1, 2003 12:45 PM
