ABS light is on after battery change
Today, I changed out the battery for a new one. The car starts and runs fine except the ABS light won't go off. I realize that it just means that the car doesn't have ABS available when needed. Any ideas on what happened? Did I short out the fuse or something? Thanks.
One more thing, which fuse needs to be removed when resetting the ECU?
Not really sure, Have you tried disconnecting the battery again and recconecting and see if the lights still on?
If it is try the dealership.
Mike,
I am going to try that tonight. I was figuring one of the connections may be a little loose. I hope that works. If not, I'll get it checked out by the dealer.
thanks
thanks
RA61825
Sep 30, 2005 03:41 PM
Mike813
Jul 20, 2003 03:04 PM
