can i use 450 dsm injectors in a b 16 intake manifold
yes.. i think you might have to change the seals though... i am not sure... but i am sure that if you search you will find all the info that you need.
you sure can, it's a tight fit when putting them into the seals in the intake manifold, but if you shave some rubber out of the inside of the seal you should be good to go.
mikegeezy
Mar 5, 2007 09:10 PM
TurboB18C1
Oct 9, 2002 10:56 AM
