d16y7 Crx Problem!?!?!
Old Oct 19, 2003 | 07:12 PM
rexer4life's Avatar
Default d16y7 Crx Problem!?!?!
Hey i have an 88 crx hf and i just swapped in a y7 cause i blew my old motor up and needed a quick fix. I used my intake and dizzy which ran fine before but it wont start. the motor turns over good and im gettin fuel but im not gettin any spark. i also just put a new cap and rotor button on. Someone mentioned resetting the ecu but how exactly would i do that?
Old Oct 19, 2003 | 07:33 PM
Redline130's Avatar
Default Re: d16y7 Crx Problem!?!?! (rexer4life)
Do you have any codes on the ecu?
Old Oct 19, 2003 | 07:37 PM
Cory man's Avatar
Default Re: d16y7 Crx Problem!?!?! (Redline130)
If you have no spark make sure that you have a functioning coil and igniter. Both are common probs on older Hondas. To reset the ecu pull the hazard fuse for 10 seconds. hth
Old Oct 19, 2003 | 08:26 PM
rsmotors's Avatar
Default Re: d16y7 Crx Problem!?!?! (Cory man)
double check you wiring
specially the main ground juction by the thermostat housing
have you done a basic ignition test
skitzboy311
Jun 13, 2010 10:56 PM
fenix4o9
Jul 8, 2007 07:26 PM
blakryder1
Sep 11, 2004 10:04 AM
2point6
Jul 14, 2003 12:02 PM
mockujin
Nov 13, 2002 07:03 PM
