swap
Old Oct 19, 2003 | 07:09 PM
wykidrex's Avatar
Default swap
what all do i need to do a gsr swap in my 88cxr,
i have tranny, motor, linkage,ecu,cv's,what am i missing. thanks
Old Oct 19, 2003 | 07:16 PM
JDMHatch101's Avatar
Default Re: swap (wykidcx)
mainly your just missing the motor mounts.
Old Oct 19, 2003 | 08:10 PM
rsmotors's Avatar
Default Re: swap (JDMHatch101)
if you have a hydro tran you have to get the cable to hydro conv.kit
make sure you have the linkage for the crx. if you have the integra linkage you can get it cut and welded to right lenght.
if you are running obd1 distributor and ecu, you need to get the obd0 to obd1 adapter
Old Oct 20, 2003 | 04:53 AM
wykidrex's Avatar
Default Re: swap (rsmotors)
what do u think would be the best swap ,gsr, b16 ,Ls,or b20 and do u know where ican get motors from.
Old Oct 21, 2003 | 06:49 PM
revhigh89's Avatar
depends on how much money u got son, and how fast u wanna go
1. LS/VTEC-complicated swap, costs a lot, hard to maintain, lots of torque and vtec( did one myself)
2. B16a-affordable-fast, reliable(more so than the lsv)
3-GSR- pretty hard to drop in, its huge, lots of work, gsr motor costs a lot,
4-LS-cheap, a lot of torque, easy to drop in, b18a....can always build it up and turbo that sukka!
5-hampsters-tie a couple to each axle. cheap, not reliable-wont go no where-
choose ur weapon.......
ScoobsAndHisRex
Nov 19, 2014 02:10 PM
onetight99ls
May 17, 2010 06:57 AM
lancerkid06
Jan 21, 2008 08:48 AM
J4k3
May 7, 2007 08:07 PM
dcviperboy
Oct 5, 2003 07:53 PM
