a6 crank in z6 block? engine building ?
Old Oct 19, 2003 | 07:03 PM
turbo sol's Avatar
Default a6 crank in z6 block? engine building ?
well since my computer just quit explorer this is the second time i am typing this. Grrrr.
i have a z6 block that has a badly spun #1 rod bearing i was wondering if i can use an A6 crank in the z6 block with either z6 rods or aftermarket rods. Most of the specs seem like they will work but others have me scratching your head.
specs (in inches) a6 / z6
main bearing journal dia. 2.1644-2.1654 / 2.1644-2.1654
con. rod journal dia 1.7707-1.7717 / 1.6526-1.6535
when crower sells their rods they have one set for 88+ 1.6 d series with a B.E. bore (Big End?) 0f 1.890"
eagle has the same set up but i am having trouble finding rod specs. what do you guys think?
Old Oct 20, 2003 | 05:31 AM
turbo sol's Avatar
Default Re: a6 crank in z6 block? engine building ? (turbo sol)
no one?
Old Oct 20, 2003 | 07:07 AM
phatrick2332's Avatar
they will work, just make sure u get rod bearings for the crank ur using, and use a6 compatible rods too.
grumblemarc
Mar 30, 2011 04:03 AM
ryc555
Sep 23, 2008 05:34 PM
alupso
Aug 30, 2008 05:31 PM
mattie_96
Oct 8, 2006 06:18 PM
mattie_96
Sep 30, 2006 02:51 PM
